So
Discussion in 'Engine/Drivetrain' started by yota4life, Jun 8, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I'm big on doin things myself an not have to pay an arm an a leg for someone else to do it. An I'm thinkin about takin on doin my exhaust basically just raising it up a little so it doesn't drag anymore. And the shop I go to said he won't raise it becuz of the sensors so that's why I'm thinking about doing it myself.
    Here's my plan get some exhaust tubing an 2 bunts for the sensors drill my holes weld up the bungs an bolt the exhaust back up just raised. Any input on this
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Sounds like you've got it figured out. Another option is to cut both sides of the bung and rotate it. Then raise everything. Relocate the cat forward or back if its under any crossmembers. I always make my own exhausts too.
  3. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Thts a good idea too but the exhaust pipe from like summit is relatively cheap an I think it would look better than having a bunch of welds
