So what vacuum lines can I remove?
Discussion in 'Engine/Drivetrain' started by IronNam, Sep 30, 2010.
  1. IronNam
    :D
    Don't mind the empty water bottle for my windshield washer fluid, haven't really used it :ROFL:
  2. .deadprez_
    .deadprez_ Member
    Miami fl
    94xcab
    man i dont know ........ i removed a lot of isht from my last car , which was a gti vr6 ..... id like to know too . :thinking: ....... im sure all the emissions stuff for starters .. then you can redo coolant lines ... then you can start thinkin wires and battery .....
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    do you want ac and to pass emmissions? if not pretty much all of em. if so none of em.
  4. IronNam
    just the A/C really, gunna keep that sucker
  5. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Good question CINN, i been wondering to.
  6. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    So we can just disconnect them and it will be fine? Im doing my timing chain right now, so if i dont need any of them i wont be putting any back. Anyone know?
  7. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I was gunna make this exact same thread tomorrow lol
  8. Litneon
    Cocoa, FL
    94 xtra cab
    Nam, we've been through this already, you even posted in the thread...
    Look here man.
    I re-installed the AC kickup, but never posted a pic. I just tucked in under the intake manifold with the rest of the wiring harness that lives there.
  9. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    the power steering idle-up (if you have it) is up to you. My cressida doesn't need it but it's torquey enough to handle with the PS at idle, I don't know how much the 22re likes it.
    EGR you can remove but it's debatable how much good it'll do (depends on if the tubes are carboned up or not) it helps prevent detonation/pinging but it dirties up the intake.
    evap/charcoal canister you can remove but it's not hurting anything.
    PCV you could, but it's better to run a catch can then to the intake so you still get some vacuum but you don't send all the crud into the intake.
  10. loluxprogress
    loluxprogress Enthusiast
    VIC, Australia
    1994 Toyota Hilux 22R
    i done an engine swap in my last vehicle, a 1986 mazda 626. i think they are also known as telstars, same engine anyway. so i done the swap, but could not figure out a few vacumn hoses. and, well, it idled high and rough, and if i disconnected some, it wasnt as high but still high. even when i adusted idle and all that crap. so, maybe disconnecting vacumn hoses affects idle?
  11. oahu grown
    Hawaii
    92 Extra Cab
    I disconnected a bunch of mines and a week later my engine died. Dunno if it was related to that or not, but i should have just not touched it.
  12. dillinja666
    ive got none. yes, none on my motor and it runs great. i have the booster hose but i need that so i can stop.
    vaccum lines dont effect idle, engine life, nada. Vaccum leaks do, if you run too lean you will burn up a motor, and it will cause your idle to increase.
  13. IronNam
    lol did you guys cap the lines you pulled?
  14. oahu grown
    Hawaii
    92 Extra Cab
    Nah i know what you mean. It was just the last thing i did before my engine crapped so im like damn, maybe i shouldnt have did that.
    And yeah nam i capped all the lines.
  15. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    either run them back to each other in pairs or most auto stores have assorted vacuum caps available.
    My cressida was nice cause I could just use a 7mgte TB with only 1 vacuum line.
