Should I keep the power steering
Discussion in 'Engine/Drivetrain' started by FOKAI12, Jun 29, 2009.
  1. FOKAI12
    FOKAI12 Enthusiast
    GREW UP IN GUAM NOW IN VA.
    1992 Reg Cab
    Is it worth the power increase if I remove my Power Steering and A/C. Or should I keep in in my truck?. What you all think what would you do?
  2. thundering02
    thundering02 Addict
    Fenton 63026
    1-2 horses on the PS. AC is similar. You have listed your truck for street and -strip- therefore I say remove both and get rid of the weight too. 25-50 lbs total.
  3. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    removing the p/s will require a manuel box, and removing the a/c meens a misarable summer heat, I'd keep them both.
  4. Toyo Trucker
    Toyo Trucker Addict
    But, is it really worth that 3-4 hp and reduced weight.
    Imagine sitting in traffic sweating your ass off all summer and having to fight your car to fit into a tight parking spot.:eyecrazy:
  5. thundering02
    thundering02 Addict
    Fenton 63026
    My BMW does not have any of the powersteering components left other than the rack. What you can do is loop the lines (or get fancy and create a block) and then you are not fighting the pump. maybe 15% worse unless you are sitting at a dead stop. Seriously not looking back. oh and the truck has more turns lock to lock so it will be easier.
    As for AC the 40 lbs + horsepower from my integra made for about .5 second faster quarter mile times. 16.5 down to 16.0
    and the 3-4 horses is for a stock engine... If you've got better engine it could free up more.
  6. HoleShot03
    HoleShot03 Member
    Maryland
    93 Hilux
    If you do take the A/c stuff out let me know. I might buy it from you.
  7. the_general626
    La Mirada, CA
    welcome to my world... but i dnt mind heat... but the tight spots are always fun lol, id leave the P/S but take out the a/c if u can stand heat like i can
  8. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    a/c is a necessity where i'm from with 115-120 degree summers you HAVE to have it...I dont have p/s on my truck..and i like it like that one less thing to fail and leak...ditch the p/s imo!!
  9. the_general626
    La Mirada, CA
    as long as ur not a complete stop not having p/s isnt bad, my wheels turn pretty good w/o it... but im used to CALI weather haha
  10. IronNam
    I'm A/C less since i did my timing chain (winter). that's about it.
  11. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Scrap 'em both! I have neither, and I don't mind. I had a VW Scirocco that was black with black leather interior when I lived in Macon, GA that had neither and was my DD.
    Then again, my truck is not my DD. My current DD has A/C and P/S. I never really liked power steering much, myself.
  12. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    I would leave the PS and AC alone... You think you dont want it now, but then after you get rid of it and drive through the heat for a good couple of years you will wish you had it... BTW, the ladies dont like a ride with no A/C. My wife would not ride in my truk until I fixed the A/C..
    And on another note, unless all your going to do is race the truck, then whats the point of sacraficing your comfort for .5 of a second?
  13. joeynational
    PHX,AZ
    91 2WD
    +1 well said!!
  14. IronNam
    Thats why when i go out with the chicks, I'll take the Camry....
    hehe, sunroof, A/C, V6, lol
  15. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    if you do remove it, let me know. i'd like it for my truck.
    as for difficulty, ive never noticed it being that hard. but if yer going for performance to the max then i say remove it all.
  16. IronNam
    ^^ like waht SD Yota said, remove the cab xD
  17. l0wlux
    l0wlux Member
    id ditch the p/s but keep it in storage but keep the a/c better that way....no power steering better handling if you decide to kick it out some on those rainy wet nights while baking in a/c cheeee heee
  18. 22r
    22r Veteran
    Maui
    just take off the belts, when u need em put em back on :)
  19. project_DragTruck_v2.0
    project_DragTruck_v2.0 Veteran
    my 86 didn't have either. I noticed only one flaw, the rag joint in the steering shaft ripped more times than I care to think about(lots of slo mo driving, off road). So, I used a piece of metal *similar* to a street sign, and a new rag joint. I traced the new joint onto the metal, cut it out, and installed BOTH in the shaft. This was one of the best redneck mods I ever did to that truck. At low speed, I could turn it lock to lock with out much muscle, and at speed the steering felt WAY more responsive.
    The 87 I just got actually has PS....I'm unsure how I feel about it yet....
    I'd say get rid of it all. Here's a good formula I found.
    1) Calculate vehicle's current weight(x).
    2) Subtract the amount of weight you’re removing.
    3) Take this new number(a) and divide it by the horse power of the vehicle (y). The number you come up with (z) will be the amount of lbs. per horse power after the reduction. (Step 1)
    4) Then divide 1 by the number of pounds (z) and multiply it by the weight before the reduction(x). This new number (b) will be the new simulated horsepower of the vehicle. (Step 2)
    5) Take this number (b) and subtract the horsepower before weight reduction(y) from it. This will be the simulated gain(s/hp (g)). (Step 3)
    Step 1: a/y=z
    Step 2: (1/z)*x=b
    Step 3: b-y=g
