Shifting troubles
Discussion in 'Engine/Drivetrain' started by manpick, Dec 30, 2012.
  1. manpick
    manpick Newbie
    Hayden, Alabama
    86 4x4
    Hey guys, I recently started having troubles with shifting.. Cannot shift with the clutch even when truck not running.. replaced slave cylinder and bled lines, but did not fix issue. Replaced clutch master cylinder and bled again. Truck will shift when turned off but will not shift when cranked. Any ideas?
  2. flacostaco
    flacostaco Toyotaholic
    Corona Southern Cali
    87 pickup
    did u bleed the lines? you might have air in them
  3. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Sounds like a clutch issue to me. Did you check for movement on the throwout bearing fork when pushinng the clutch?
  4. Scomber
    Scomber Enthusiast
    Down East
    What's the state of the tranny lube? Could this also be a synchro issue?
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Worn thro bearing or pressure plate can cause these issues like under construction mentioned
  6. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    or it could just need a clutch....
  7. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
  8. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Did you try adjusting your clutch master properly
    sounds by the path you have done thus far shows that that is the issue and you master was at fault then when replaced you did not readjust the new one
    have fun
  9. JOE_1985
    JOE_1985 Veteran
    87 custom
    Bet the clutch disk has broken spring. Go drop the trans
  10. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    May also be your shift rails
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    ive seen broken shifter fork/rail. not good. recommend to remove trans and inspect, mite as well put in a new clutch while ur at it
  12. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    Just went thru the same issue with my 4x.First changed slave still same,then master still same,inspected pedal throw and play in the clutch masters firewall area(common area for rust on guam I think brake fluid promotes rust)anyways all good there.Dropped the trans and transfer case(a b!tch btw)and found a blown out pilot bearing so replaced that and new clutch and pressure plate.Now it's cherry like auntie Marry.I'm positive the fingers on the pressure plate were weak already and wasnt giving full throw.
