Shifting problem
Discussion in 'Engine/Drivetrain' started by yota4life, Apr 27, 2010.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I've been noticing that lately if Im drivin my truck for a long period of time that it's hard to put in gear. This is kinda vague but idk how else to describe it.
  2. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    Whens the last time you changed the gear oil in it? does it leak? caked with gunk? how many miles? has it been rebuilt? what gears does this happen?
    Start with answering these questions so we can further figure out what the issue could be.
  3. planemos
    planemos Toyotaholic
    British Columbia
    Sometimes it's as simple as replacing the shifter bushing. It's all accessible from inside the cab.
  4. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I haven't replaced the gear oil. But now I'm thinking I should. It has about 184000 an it's through every gear. I don't think it leaks but ill check tomoro
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    does your clutch feel any different when this happens? if you pump it does it get easier?
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Clutch feels the same. An no but if I slam the clutch down it gets a little easier
  7. SD YOTA
    if its all gears and especially when it warms up im thinking something other than the tranny.... possibly clutch component related..... when was the last time the fluid in it was changed? check and see if there is any binding in the slave cylinder when it is pushed in. check for any leaks at the slave and at the master....... when it does it again.... have someone push down on it and hold it. take a look inside the resivoir and see if any bubbles come out after a few seconds..... if it does, either one or the other is passing fluid and not letting the clutch disengage fully.....
    always rule out the cheaper things first. :waytogo:
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ya I was thinking it was my clutch master cylinder or something like that. Might just have to get a new one an see if that helps. I just hope it's not the tranny.
  9. NotAvailable
    NotAvailable Addict
    might as well change the gear oil and clutch slave since theyre all easy
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    How do you change the gear oil? Did it before on my old yota but it took forever so I kno it wasn't the right way
  11. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    just take out the drain plug on the bottom, then fill it back up on the side, a siphon pump makes it so much easier, you wanna fill it up until you can feel the oil when you put your finger inside the fill hole
    and also check your shifter bushing, its a cheap replacement..I almost bought a new tranny because mine was doing the same thing yours did, i took it out of the truck and everything, thank god i didn't buy it. the new bushing made it feel like new again. Here is some links for it
    http://www.marlincrawler.com/transmission/parts-upgrade/heavy-duty-shift-lever-ball-seats
    http://www.brian894x4.com/Shifter.html
  12. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Thnx man for the link I'll try tht first. How hard was it to do
  13. NotAvailable
    NotAvailable Addict
    shoiuldnt be hard. i never replaced the bushing b4. i only changed gear oil and clutch slave and master. and the clutch n flywheel...
  14. joeynational
    PHX,AZ
    91 2WD
    considering i already had the tranny out, lol it was very easy..shouldn't be any harder with it still in the truck, took me 20 minutes tops
    mine was exactly like the picture in the link, completely disintegrated
  15. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I'll have to do it asap probably order that piece Friday. Hopefully it helps
  16. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
  17. joeynational
    PHX,AZ
    91 2WD
    Bernie thats an older model right? Mine was easy to put in the new bushing has slots cut into it to make it easier, but once you get the shifter out of the tranny you have to push down and twist to get to the bushing, was yours the same way?
  18. burnzya
    bodied 73 hilux
    that is on a 85 model. i didn't do the write up, grant did. i think he is signed up on here too, but doesn't come on much.
  19. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Ok so it seems pretty simple an shouldn't take long. From one of the links you basically just push down with a cloth an turn counter clockwise. Pull the old one out with your finger get pliers pull off the shifter one. Push the new one down into the tranny an push the other onto the end of the shifter. Tht sound about right?
  20. joeynational
    PHX,AZ
    91 2WD
