Shift seat and bushings???
Discussion in 'Engine/Drivetrain' started by GrantH, Mar 28, 2010.
  1. GrantH
    GrantH Addict
    Hattiesburg, MS
    What's going on guys, i've got an 85 toyota and i'm trying to find the parts needed to restore my shifter feel. It's got a lot of slop at the shifter that I would like to get tighter if possible.
    I do not know what 4 speed I have as we bought a parts truck when I had m frame built. The builder used the parts truck tranny to mock up and it ended up mounting further back than my original. This made it where he had to make an adapter once we figured it out.
    Can anyone help me out here on what parts I need?
  2. GrantH
    GrantH Addict
    Hattiesburg, MS
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    more than likely that white one will be what you need. only other way i an see verifying your trans is to compare it to the pictures of the ones on their site.
  4. rajzswap
    rajzswap Addict
    CA
    89 2jz pickup
    You'll need both bushing to get the best results. They both wear out over time so replacing them both would be your best route and they are cheap
  5. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Like SDYOTA said, the white one is for you.
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Go to a yota dealer. $15 for both shifter seat and cup.
