Name: Russell Location: Columbus, IN Payment: Paypal or cash on pickup Shipping: small stuff sure. big stuff no. might deliver or meet halfway for gas money. Need to clean out, stuff I'm not using/swapped out is piling up. everything's OBO. 93 4 cyl 2wd P/U ECU and engine harness. (electric speedo) Got it used, realized it won't work in my 91, collecting dust since. $75 91 4 cyl 2wd P/U -Axle: 3.58 7.5" open. diff and bearings are great: no noises or vibrations. changed the fluid 10k ago with new pinion seal. drums are good, needs shoes. If it's not sold by 7/15 it goes back to the junkyard as a core. $100 *still in my truck for a few days till I get time to swap it for the junkyard 8" 3.08. There are 2 more in the yard if anyone's lookin) -cluster. No tach, no trip. Gauges work, 236,189 (can be changed, I won't for you. check your local laws) front clear part is slightly pitted from PO using brake clean nearby but cleaned up semi-decent. I drilled a hole to try to swap it onto my new cluster w/ tach button but that didn't work. $30 -AFM. From my truck, got another to troubleshoot but this wasn't the problem (plug wires were shorting when humidity was just right). $60 -TPS. Same story as the AFM. $40 -intake tube that goes over radiator $10 -airbox with hot glue plug for PAIR line $10 -Ebrake handle assembly $20 -Hood release handle and bracket that goes in the cab. $10 Misc: roll bar. single ring, 3" tube. bolts to the bed with 4 bolts at each tube end (16 total) $100 Most of the stuff is what it is but I'll get some pics when I find my phone USB cable.
