Second fuel tank
Discussion in '1989-1995 Pickup Discussion' started by ancientgrubs, May 15, 2020.
Tags:
  1. ancientgrubs
    ancientgrubs Newbie
    Hi Folks!
    I have a ute that needs additional fuel range and redundancy.
    The ute is a 1995 Hilux US model with a passenger fuel tank. Build date Jan 1995
    83000 original miles.
    Extended Cab. 4wd.
    Stock bed is gone.
    ---The exhaust is rerouted under the cab to a snorkel that goes up behind driver side cab corner for fording.
    ---This leaves the bed underside available for the second tank.
    ---Tank must be mounted in between axles. Aft of axle will change weight distribution.
    ---Canopy is being mounted along with hitch receiver platform. Weight is going to be saved for that.
    *I require efi fuel pump redundancy. *
    ---I can mix and match any manufacturer, as long as line pressures are right for the EFI.
    *Toyota parts preferred.*
    ---I already have a system selected for tank switchover and gauges. Valves come from the Biodiesel community. They have amazing 3 way viton seal valves with threaded ports that are designed for heavy usage and oils.. NO FSVK-1 fuel valve bullshit.
    I design circuits for my job. I am designing the control systems for the pump and gauges with LTspice.
    I am keeping emissions equipment systems.
    Based on the preceding parameters, I need brainstorming about what fuel tanks fit in that position.
    Once I have the information I need, I will create a write-up with the build for the community.
    Thank you!
