rust nightmare
Discussion in 'Exterior/Body' started by Humbol, Apr 6, 2010.
  1. Humbol
    Humbol Member
    Maui, Hawaii
    89 toyota pickup single cab
  2. jetas
    Are those holes? Are they close to being holes? if so, make a filler panel somehow and weld. Or do a slidiing rag top:cool:
  3. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    yea.............. punch through the rust or cut it out entirely and make patch plates..... weld them in place, grind, sand and make em flush again.
  4. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    how are the edges of the roof panel (at the front, rear, and near the drip rails)??
    if those areas are in decent shape, i would suggest replacing the roof skin itself from a good donor vehicle. it's just a series of pinch welds holding it on. the panels are usually very cheap at scrapyards too.
  5. Humbol
    Humbol Member
    Maui, Hawaii
    yeah some are holes already. should i take it to a body shop? cuz i do not know anything about body work.
  6. jetas
    if you take it to a shop make sure u tell em u want the all that sh!t replaced. cuz if not all theyre guna do it tape the inside and throw filler all over
  7. IronNam
    yeah seriously.
    those aren't holes.... those are craters.
    only fix i can think of is to cut it all out and weld in a new skin...
  8. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    Replace it, less time and money.
  9. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    or if you want to ease your warpage and work, find a donor truck and cut the roof off in the pillars, up near the top, and swap entire roofs that way. same as chopping a top without removing any height. front and rear glass comes out, but doors can and should stay on to check alignment.
