running lean cel
Discussion in 'Engine/Drivetrain' started by 89blaster89, Dec 11, 2013.
  1. 89blaster89
    89blaster89 Enthusiast
    western wa
    93 singlecab
    im trying to figure out why im running excessively lean mixture, im getting the cel for it, i checked the o2 sensor with the modus and its good, im gonna throw in a fuel filter tommorow and see if it goes away...
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    vacuum hose leak... possibly a loose intake connection between the filter and the throttle body... check and make sure the trap door on the afm moves freely when pushed... always check all the easy stuff first.
  3. 89blaster89
    western wa
    93 singlecab
    yea i smoke tested it, no vacumm leaks and the intake is good also
  4. SD YOTA
    ok, have you had any loss in power? freeway speed/power still good? if it was a fuel filter, you would notice it would have a lack of power as if it was running out of fuel.
    the other issue could be it having clogged injectors... or an injector or two that are not flowing well...
  5. 89blaster89
    western wa
    93 singlecab
    it does seem like around 1500-2000 rpms it seems like it doesent have as much get up like it used to? i hope its not my injectors, big job
