Does anyone know where you can get an aftermarket rubber boot that goes on top of the transmission tail piece around the shifter? I have a W50 that has a ripped one and I need to replace it.
If you decided to go OEM, then the part number is 33555-31011. If you are also looking for the rubber boot that sits under the round trim ring, then that one is discontinued.
Nice 82rn34. Thx for the part number. I will follow that good post with a link I found by using that # 33555-31011 - OEM Toyota BOOT, SHIFT & SELECT
