Rpm's at 70 with sr5 cluster and 18s
Discussion in 'Interior/Electronics' started by Lotoy, Dec 4, 2013.
  1. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    What rpm's are you guys running at 70mph with 18s? I did the cluster swap bout 1year ago! Yes I calibrated the the tach with dial behind the tach/speedo! I think my runs around 3500 +or- I meant to check on the way home today but forgot? Any thoughts,suggestions!!! Please
  2. Litneon
    Cocoa, FL
    94 xtra cab
    What trans? That seems really high for a 5 speed. My auto runs around 2500 ish? 3.73 gears....
  3. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    I will recheck it! Yes 5speed trans! I may need to dial it back a bit!
  4. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Thanks for the info!
  5. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    I do about the same at 70 as you. Little over 3000. That's with 215/45/17 rear tires, 4.10 gears and a W52. I want mellower gears out back. Stretch the gears out a bit. First few are too quick.
  6. IronNam
    275/35/18 + 3.42's + W58 from SC300 = 2000rpm's @ 60mph, 2500RPM's @ 70mph, 3000RPM's @80mph, as far as I've calculated and actually driven.
    Figure out your tire size, gear ratios, and rear end.
  7. standardbyker88
    lynnwood, wa
    That's what I did in reverse for various gears and speeds. I don't run a speedometer in my rigs. Just tachs. Easier to adjust mental notes with tire changes than speedo gearing.
  8. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Thanks guys for the help!
