Round 2
Discussion in '1989-1995 Build-Up/Project Threads' started by Newyota1994, Mar 6, 2016.
  1. Newyota1994
    Newyota1994 Member
    So Iv started a second tare down on my truck gonna post all of the first build and it was all done outside the first go around and now I actually have a garage so I'm taring it back down full cab off build
  2. Newyota1994
    Newyota1994 Member
    image.jpg The way I got her and she needed a lot of work
  3. Newyota1994
    Newyota1994 Member
    Paint and interior needed a lot of work along with sheet metal image.jpg image.jpg image.jpg
  4. Newyota1994
    Newyota1994 Member
  5. Newyota1994
    Newyota1994 Member
    Cleaned her up a lot not to much was done and she was ready to drive so I thought but I needed the front to lay harder image.jpg
  6. Newyota1994
    Newyota1994 Member
    Never got any good pictures of how terrible the original rear set up was but after bags rubbing and being separated inhalf it was time to rebuild the back setup
  7. Newyota1994
    Newyota1994 Member
    image.jpg Remounted rear bag mounts decided to go bag on bar image.jpg Relocated tank to under the bed instead of being bolted to bed floor image.jpg air tank mounted sorry for crappy pictures like I said it was done outside and a lot of times at night
  8. Newyota1994
    Newyota1994 Member
    image.jpg Bed lined the frame from the cab back image.jpg Both sides done and welded in now time to make it pretty
  9. 90yotaboy
    90yotaboy Newbie
    S.C.
    90 single cab 4cyl mini truck
    keep up the good work will be following your build
  10. Newyota1994
    Newyota1994 Member
    There's alot to upload this was just from the first build just to make it safe to drive right now it's completely torn down custom control arms to a back half but that's for later
  11. Newyota1994
    Newyota1994 Member
    image.jpg At this point got the bed back on and started sanding down all crappy purple
  12. Newyota1994
    Newyota1994 Member
    Started fixing body work image.jpg the tail gate was welded just no filler was ever added im terrible about getting before pictures
  13. Newyota1994
    Newyota1994 Member
  14. Newyota1994
    Newyota1994 Member
    image.jpg First year they brought slammin and jammin back so I was under pressure to have here looking good and running didn't get a lot of pictures Becuz I was still assembling the truck thirty min before we where leaving out of town with our group paint was still almost wet at this time image.jpg photo from the show
  15. Newyota1994
    Newyota1994 Member
    So now I'm current just up to the tear down im under now so I'll start those photos after a few
  16. Newyota1994
    Newyota1994 Member
    image.jpg Forgot one here's the dash I did in it before the show
    Mikerocosms likes this.
  17. Newyota1994
    Newyota1994 Member
    So I drove the truck around for about a year in the brown and then I started getting ideas on how I wanted the truck to be and then this happened image.jpg and it kept going further and further image.jpg when I finally pulled everything out I found out there was way more underneath that needed to be fixed
  18. Newyota1994
    Newyota1994 Member
    image.jpg And the official tare down begain image.jpg image.jpg image.jpg image.jpg image.jpg The fun begain image.jpg
  19. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    In your old set up did the tank poke through the bed (when It was behind the axle) or was your bed floor raised.
  20. Newyota1994
    Newyota1994 Member
    If the bed floor would have been there it would have been hide underneath I ran the bars holding the tank at the same angle the notches where I got the truck all hacked up reason I'm on build 2 I fixed enough the first go around to drive it for awhile but there was stuff that I never really noticed before that needed attention really bad
