Rough Idle
Discussion in 'Engine/Drivetrain' started by SIX_SEVEN_ONE, Dec 11, 2011.
  1. SIX_SEVEN_ONE
    SIX_SEVEN_ONE Member
    Hey TMers,
    Been having some issues idling and cant figure it out.
    It idles really low when you turn it on and takes about 5 miles of driving to idle good.
    At first I thoughtmaybe cold start injector but it seems its not only when cold but everytime you tun it on. Whether it's cold or warmed up.
    Also when cruising in gear and pressing on the pedal very slightly it sorta bogs and bounces around but when you give anything over 10% throttle it's fine.
    Doesn't matter what RPMs but it's really bad between 2500 and 3200.
    Please help me with this matter. I love my truck but hate driving cuz of this.
    BTW its a 85 SR5 2WD and still EFI..... Thanx in advance!!
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Could be a vacuum leak. Mine had been doing something similar, finally found a split line, replaced it and it's gone...
  3. SIX_SEVEN_ONE
    Thats another thing I forgot to mention. I removed alot of the vacuum lines that I "assumed" I dont need.
    May need to look into that.
    Thanks
  4. SIX_SEVEN_ONE
    Oh and another thing, the idle screw has to be pretty far out. Maybe IAC??
    Thanks
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    Did all this start after you undid all the vacuum lines?
  6. SIX_SEVEN_ONE
    It has since I first got it. Its just pretty bad now. Its getting pretty fustrating
