rocker arm shaft removal
Discussion in 'Engine/Drivetrain' started by Doerr, Feb 23, 2010.
  1. Doerr
    Doerr Newbie
    Sheridan,Indiana
    1988 4x4 4cyl 5 speed standard cab
    Can someone tell me if I can remove the rocker arms and their shafts without removing the head and replacing the head gasket. This is on a 88 truck 22re
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    yeah. just take out the bolts holding the shaft down. it should pop out. just make sure it torques down properly when you reinstall it.
  3. Doerr
    Doerr Newbie
    Sheridan,Indiana
    Arent those bolts also the head bolts or are they seperate? Thanks for the reply.
  4. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    they are the head bolts, the proper thing to do would be to replace the head gasket it will be a gamble if it will seal correctly from removing the head bolts.
  5. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    BTW if you are going to remove the rocker assy, loosen the shaft retaining screws before removing the assy.
