anyone have a part number or source? i used FJ40 turn signals but sat crooked? maybe i did not install correctly?
These pop up on Ebay from time to time... Front Fender Lights Toyota Hilux Pickup Truck RN10 RN20 RN25 RN30 RN36 RN40 | eBay Looks like you could remove the posts.
Those ebay ones are nothing close to the stock ones. I pulled my new ones out and took some pictures of the original part numbers, have to start looking through junk yards for a set, you'll have no luck finding these anywhere here at the dealerships. Right side driver, part number. Left side part number. Left side one.
Surprisingly, eager myself, I googled one of the part numbers and found a couple online from dealers for very cheap, if these are indeed in stock I would definitely try to snag a pair up!
The lenses are the same mold number as some FJ40s. I can't imagine the rest of the housing is much different.
I know this is an old thread but thought I'd share: I purchased new FJ40 turn signals mentioned above for my Hilux RN12 and can confirm they are exactly the same, except for the small plastic support. That piece is taller and has a steeper angle for the FJ's fender. Everything else is the same. I just cut the plastic supports down to sit lower and match the angle of the Hilux's fender (used a dremel with a plastic cutting blade and some 100 grit sandpaper on a flat surface. Came out pretty good. I think to be perfectly accurate I should shave another 1/8" or so off but I'm sticking with it. Part #: 81510-60200
