Reverse grind... Ugh
Discussion in 'Engine/Drivetrain' started by brovender, Aug 9, 2012.
  1. brovender
    brovender Enthusiast
    Upstate SC
    1973 Hilux RN27
    I'm new to the board and have recently acquired a '74 Hilux barn find in exchange for my '73 Dodge Dart (sweet trade if you ask me :D)
    It has an 18R-C and L40 4-speed tranny. The main issue I'm having is when I put it in reverse it grinds like hell and then engages, and seems to be my only gear I'm having the issue with. What can be some of the causes of this? I haven't torn into it yet, and the PO said he's adjusted the clutch but he also didn't seem too knowledgeable about... pretty much anything.
    Any insight/advice is much apppreciated!
  2. 22R88
    22R88 Veteran
    South Louisiana
    1988 Reg Cab Deluxe RN50
    Pics of the Barn Find and Dart please !!
  3. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Welcome got any pics .swap the hole motor and trans to a 20r or 22r much better off
    Love dodge darts pics if u got them
  4. MercuryMan
    MercuryMan Member
    Springdale, NWA
    1974 Hilux
    Darts are cool but the Hilux is more useful for sure. Welcome to the classic Toyota party.
    Check your clutch fluid reservoir to make sure its got good fluid and make sure your clutch is adjusted properly. I did this to my '74 and it helped. Occasionally it will still complain about going into reverse, but it's more of a clunk than a grind. Sometimes double clutching (pressing the pedal twice then engage) will also help or going to 1st and then head for reverse. Once you get it sorted you should do a fluid change to remove those gear shreds.
  5. brovender
    Upstate SC
    1973 Hilux RN27
    I'll post pics later when I can. I agree MercuryMan... My Dart was a four door slant 6 anyways. Bulletproof but lacking in the cool factor.
    I'll give the double clutch and the 1st to reverse a shot. Any threads on clutch adjustment? This is my first Yota and manual transmission vehicle I've ever owned. I love it though.
  6. brovender
    Upstate SC
    1973 Hilux RN27
    I've considered a 20R swap though. Not now, but maybe later!
  7. TRfknD
    TRfknD Veteran
    The Woodlands, TX via (Guahan)
    96 Taco / 05 Tundra
    Also, try shifting from 2nd then into reverse....been doing this since I've owned a TOY! lol;)
  8. brovender
    Upstate SC
    1973 Hilux RN27
    Thanks for the tips! So far so good with forward shifting then going to reverse... no more grinding/clunking!!! Does anyone know the procedure for changing the clutch fluid? Mine's looking a little too dark.
  9. MercuryMan
    MercuryMan Member
    Springdale, NWA
    1974 Hilux
    Basically same as brakes, same fluid too. Empty out as much as you can from the master (to shorten the job) and refill with fresh, open bleed nipple on operating/slave cylinder with hose attached, make sure master cylinder stays full, and proceed to bleed until the fresh is coming out. If you have a vacuum pump you can do this by yourself by just vacuuming the old out while filling with new (much faster), otherwise get a buddy to work the pedal and bleed it clean.
  10. brovender
    Upstate SC
    1973 Hilux RN27
    Where is the slave cylinder located? Like I said... I'm new to this. :confused:
  11. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    It's down there on your transmission should have a hard line going into it think it's a ten mm bleed valve or a eight mm can't Rember it's easy to spot just look for the bleed screw on the end of it
  12. MercuryMan
    MercuryMan Member
    Springdale, NWA
    1974 Hilux
    Go to your passenger fender and peer down behind your starter. You will see a rubber hose clamped to your engine that turns into a hydraulic hose and it's leading to the slave. The bleed nipple is on the passenger side of the cylinder. It's easy to get to if you jack up the front of the truck-it may be fairly dirty and caked up if your truck has ever had any leaks, if so spray it with brake cleaner and brush it clean to make it easier.
    EDIT: Sorry scrub i didn't see your post, didn't mean to echo.
  13. brovender
    Upstate SC
    1973 Hilux RN27
    Thanks guys! :bow:
