Return fuel line
Discussion in 'Engine/Drivetrain' started by Sunk, Mar 15, 2024.
  1. Sunk
    Sunk Newbie
    Pa
    92 Standard Cab
    Anyone have a part number for the return fuel line?
    I've searched these forums with no luck.
    Looking to replace the hardline that goes under cab and then into rubber under the bed.
    My tank is relocated and stock but I think the lines are all stock as well.
    Just having a hard time finding images that match what I have currently.
    I could be wrong and it was replaced but the bends in it seem to be factory.
    Thanks
  2. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Aftermarket ones will definitely not have the same sharp bends as OEM.
  3. Erwin Merida
    Btw , try these.
    Main Line 77205-35170, Return Line 77255-35550
  4. Sunk
    Sunk Newbie
    Pa
    92 Standard Cab
    Thanks!
    I did have those numbers. I tried to.find them online and everything is saying discontinued for the return...
    I have no problem making the line. It goes into rubber on each end so I dont even have to flare it.
    I guess I'll remove it and try to get the tube diameter to bend a new one.
    Erwin Merida likes this.
  5. Erwin Merida
    You can also try a scrap yard.
  6. Sunk
    Sunk Newbie
    Pa
    92 Standard Cab
    Replacement done with a roll of 1/4 steel line. Made the bends and got it all tied it!
  7. Erwin Merida
