Retighten head bolts?
Discussion in 'Engine/Drivetrain' started by mldave, Oct 19, 2010.
  1. mldave
    mldave Newbie
    On my 86 Toyota truck 4x4 2.4 EFI..suppossed to be a new engine..now have 1100 or so miles on it.Do the head bolts have to be retightened on it?
  2. Litneon
    Cocoa, FL
    94 xtra cab
    I've never heard of this, if they were torqued to the proper specs originally, they should be fine.
    It's just a stocker right?
  3. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    I retorque mine... its a simple task so why not...
  4. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    after installing a new head gasket you heat cycle the motor then re-torque.
    there should be break-in instructions with the motor, or the builder could tell you.
    but the motor should be broke in by now with 1kmi.
  5. Litneon
    Cocoa, FL
    94 xtra cab
    Interesting, never knew that. What do they do from the factory? And does this apply to all engines?
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    every car is tested from the factory, couple miles or so i bet.
    but theres break-in instructions that come with a new car.
    not sure about all motors, but for 2Xr's ya. says so in any instructions ive read, its even in the writeup
  7. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    If you do re-torque them headbolts, please take the extra time to check your valve lash aswell... :cool:
  8. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    ive done lots of head gasgets at work and i have never heard of having someone come back to get the bolts re-torqed. this isnt only for toyota but every make ive done....
    i think the reason that there is a certain pattern to torq the bolts in eliminates the need for a re-torq after 'x' amount of mileage/heat cycles.
