This is something that can be found via google, the search function on this website, and numerous other sites. Rather than ask a "retarded question", use our search function to find the answer. Once you know what static drop means, you can then search our forums, or others, and figure out how to go about completing a static drop.
Static drop is using steel parts to lower your vehicle witout being able to adjust it easily. A adjustable suspension is the opposite an example is either airbags or hydraulics. A body drop is litterally lowering the body on the frame. Bd is a lot of work and involves a whole lot of cutting and welding.
everyone starts somewhere and questions are the 1st place.Here's a visual to explain better.torsion lowering for 84 toyota p/u - YouTube drop spindles 84 toyota pick up - YouTube
