Filed under: Truck, Recalls, Toyota In a dealer communique sent out today, Toyota has announced the voluntary recall of some 8,000 2010 Tacomas that could suffer from a defect in the front propeller shaft. Pickuptrucks.com reports that a crack can form in the rear joint, causing the driveshaft to come loose from the truck. Obviously, this defect will only affect four-wheel drive models, so standard two-wheel drive Tacomas are left out of the recall. According to Brian Lyons, Toyota's head of safety communications, "Most of the vehicles [included in the recall] are in the pipeline in Toyota's distribution system or on dealer lots." Affected owners can contact Toyota at 1-800-331-4331 for more information, and Toyota dealers will perform a ten minute visual inspection of the trucks. Naturally, if they find a fault with the prop shaft assembly, it will be replaced free of charge. [Source: Pickuptrucks.com]Report: Toyota recalling 8,000 2010 Tacoma 4WD pickups over driveshaft defect originally appeared on Autoblog on Fri, 12 Feb 2010 17:04:00 EST. Please see our terms for use of feeds. Permalink | Email this | Comments Read More...
