Report: ABC News faked at least one part of runaway Toyota report
Discussion in 'Industry News' started by NewsBot, Mar 8, 2010.
  1. NewsBot
    NewsBot Grand Toyotaholic
    Filed under: Recalls, Safety, Toyota
    Late last month we wrote a lengthy post about problems with an ABC News report that purported to show a Toyota Avalon racing out of control without setting a diagnostic fault code. While we primarily focused on the technical side and analyzed whether the problem was realistic, the crew at Gawker took a hard look at the video in question and noticed something fishy.
    It appears that an editor or producer at ABC felt they could pull a fast one on the audience and used some B-roll in the report showing the tachometer needle sweeping rapidly from near idle to over 6,000 rpm. That clip was injected at the precise moment when David Gilbert triggered his simulated sudden acceleration. As you can see from the screen cap above, the shot of the tachometer clearly shows the warning lights for the parking brake on, the doors open and the transmission indicator in park. The camera operator shot this segment separately so it could be used to illustrate a point in the report, and ABC claims that getting a steady shot during the test would've been both difficult and dangerous.
    The B-roll shot doesn't indicate anything conclusive one way or the other about the validity of the test and certainly doesn't stand as proof of anything being rigged. However, the lack of transparency by ABC and Mr. Gilbert regarding the specific procedure doesn't add to the credibility of either the claims or the report, and the lack of clarity by Toyota in its response to Gilbert's assertions doesn't do the automaker any favors, either.
    [Source: Gawker]
    Tired of Toyota recall news? Try out the recall-free version of Autoblog.Report: ABC News faked at least one part of runaway Toyota report originally appeared on Autoblog on Mon, 08 Mar 2010 09:58:00 EST. Please see our terms for use of feeds.
    Permalink | Email this | Comments
    Read More...
  2. Shadetree Mechanic
    Shadetree Mechanic Addict
    Emerald Triangle, CA
    :eek:Wow... Just when I was thinking the news media couldn't possibly fail us any more...:brickknock:
  3. IronNam
    Dan, that Avalon was rigged.
    Pretty much, what they did was create a WOT signal, by just splicing wires, not from the pedal signal.
    you can do this from other electronic throttle bodied cars.
    which is something that most news viewers dont even know!
    in other words, its like having you drive your truck, and I rigged a cable to your throttle body, and i pull on my cable.
    of course, the truck would stop first, the 22R/RE won't go :D
