Repair work
Discussion in '1984-1988 Build-Up/Project Threads' started by TRUCK ACTION, Oct 14, 2021.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So having to do some repair work to my front bumper/valance, damaged it hitting a speed bump I didn't see.
    My Mini Truck friend Ricky & his brother Rob from Virginia are out working & came over on Monday so leaned a hand pulling in off & straightening the brackets. Which I decided to strengthen up with fish plates.
    So made a pattern & had my friend & neighbor cut out with his plasma.
    Today will finish that up & do the rest of repair & repaint work.
    At the same time now the truck won't start, after a little trouble shooting found that no spark,& it seems that the FireBall ignition took a dump!!
    New unit on the way from LC
      File size:
      61 KB
      21
      File size:
      74.1 KB
      22
      File size:
      67.8 KB
      20
      File size:
      73.8 KB
      19
    Perkolator likes this.
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Well the replacement unit , Fast Ignition , did the job, truck started right up!
    On with the paint work, got to get this done has a 3 day show this weekend!
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Made some head way , will remove the rear section of my exhaust so can work behind the area , have to get a steel tube stck to pug weld in behind the lower part of the roll pan for strength, & a piece of fat stock for behind where it tore. 2.jpg 3.jpg
    Will repaint all the lower section all the way around to the rear wheel well.
    Erwin Merida likes this.
