What do I have to remove to drop my oil pan. Do I have to remove the tie rods or any steering components to remove the oil pan. I tried to drop oil pan and can not drop it. I have removed the cross member and all the plates that I thought were stopping it but I don't have any room to drop it. Can any one walk me through it. Thanks
if nothing is physically in the way, try tapping it with a mallet. maybe there is some silicone holding it on. if something is blocking it, maybe try taking a motor mount loose and jacking up the motor a bit.
easy as pie, all you need to do is unbolt your pitman or idler arm ? the one on the passenger side of the truck. then push the center drag link out of the way.
You might want a puller. Or whats called a pickle fork. Just be careful if u use the fork....it will tear the grease boot.
just unbolt the idler arm....... no need to wipe out the tie rod..... unbolt idler arm from passenger side of the frame.
Once I unbolt the idler arm from the frame should the oil pan fit and just drop out. cause that is what has been stopping it from dropping.
I unbolted the steering linkage. Then i had to unbolt the motor mounts and jacked it up (all the way.. lol didn't find out til the next morning...) then i tried getting it out.. the crossmember was in the way,.... well... then you gotta remove the oil pickup thing.... once you get that out... everything comes out sooo easily.
