recommended camshafts
Discussion in 'Engine/Drivetrain' started by 82yotaHI, Jan 5, 2015.
  1. 82yotaHI
    82yotaHI Newbie
    Howsit fella's. I just purchased a 82 toyota pickup.It has a 22r with 77000 original miles. I just swapped out the factory carburetor for a brand new 32/36 weber. Im also getting ready to install the shorty headers from LC engineering connected to a flowmaster super 44 series muffler. What i want to know is if anybody can recommend a good camshaft that i can drop in to this bone stock motor. Would appreciate the help. Thanks
  2. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Rather than wait for a skewed opiinion and results from people with probably really different setups..I would contact LC engineering...they are a better source for this type of info. If I bought a cam off someone elses opinion and it was too lopey or not correct for my driving style then Id be pissed, ever try to return a used cam?
  3. static808
    static808 Member
    Vegas and hawaii
    1978 toyota pickup single cab long bed
    Use lc torque cam it's a good small gain for u hawaiian
  4. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    Outlaw cam!!!!!
    lol jk
    na, like Xs said, call LC. they will help u pick the right one for ur set up, for what u want/plan to do.
  5. SloPoke
    SloPoke Member
    corner of 33rd & go to hell
    93 standard cab dx
    Desktop dyno numbers from Gnarly4X on Pirate.....
    22RE – Stock, Doug Thorley header, opened exhaust (2” to 2.25”)
    EB261C – Duration @ .050” = 222, Valve Lift .410”, 110d Lobe Center, Valve Lash = .008/.008
    1200 RPM – 85.2 brake tq, 19.5 brake HP
    1400 RPM – 93.7, 25.0
    1600 RPM - 102, 31.2
    1800 RPM - 109, 37.3
    2000 RPM - 118, 44.9
    2200 RPM – 129, 53.9
    2400 RPM – 136, 61.9
    2600 RPM - 142, 70.3
    2800 RPM - 147, 78.3
    3000 RPM - 150, 85.7
    3200 RPM – 151 brake tq, 91.8 brake HP
    3400 RPM – 150, 96.9
    3600 RPM – 144, 98.9
    3800 RPM - 140, 101
    4000 RPM - 136, 104
    4200 RPM – 132, 106
    4400 RPM – 129, 108
    4600 RPM - 127, 112
    4800 RPM - 127, 116
    5000 RPM - 125, 119
    5200 RPM – 122, 121
    5400 RPM – 117, 120
    5600 RPM – 109, 116
    EB268 D=218, Lift=.425”, LC=110, VL=8/8
    1200 RPM – 88.8 brake tq, 20.3 brake HP
    1400 RPM – 97, 25.9
    1600 RPM - 106, 32.1
    1800 RPM - 112, 38.3
    2000 RPM - 121, 46.1
    2200 RPM – 132, 55.2
    2400 RPM – 139, 63.3
    2600 RPM - 145, 71.6
    2800 RPM - 149, 79.3
    3000 RPM - 150, 85.9
    3200 RPM – 150 brake tq, 91.4 brake HP
    3400 RPM – 148, 96.1
    3600 RPM – 143, 98.3
    3800 RPM - 140, 101
    4000 RPM - 136, 103
    4200 RPM – 132, 106
    4400 RPM – 129, 108
    4600 RPM - 128, 112
    4800 RPM - 128, 117
    5000 RPM - 125, 119
    5200 RPM – 120, 119
    5400 RPM – 114, 118
    5600 RPM – 107, 114
    EB270 D=222, Lift=.430”, LC=110, VL=8/8
    1200 RPM – 82.2 brake tq, 19.5 brake HP
    1400 RPM – 93.5, 24.9
    1600 RPM - 102, 31.1
    2000 RPM - 118, 44.8
    2200 RPM – 129, 53.8
    2400 RPM – 135, 61.9
    2600 RPM - 142, 70.2
    2800 RPM - 147, 78.2
    3000 RPM - 150, 85.6
    3400 RPM – 150, 96.8
    3600 RPM – 144, 99
    3800 RPM - 141, 102
    4000 RPM - 137, 104
    4200 RPM – 133, 106
    4400 RPM – 130, 109
    4600 RPM - 128, 112
    4800 RPM - 128, 117
    5000 RPM - 126, 120
    5200 RPM – 123, 122
    5400 RPM – 118, 122
    5600 RPM – 111, 118
    Putney Machine 230-440 D=230, Lift=.440”, LC=110, VL=8/8
    1200 RPM – 78.2 brake tq, 17.9 brake HP
    1400 RPM – 87.1, 23.2
    1600 RPM - 96, 29.3
    1800 RPM - 104, 35.5
    2000 RPM - 111, 42.7
    2200 RPM – 123, 51.5
    2400 RPM – 129, 59.1
    2600 RPM - 136, 67.2
    2800 RPM - 143, 76
    3000 RPM - 147, 84.2
    3200 RPM – 150 brake tq, 91.1 brake HP
    3400 RPM – 150, 97
    3600 RPM – 145, 99.7
    3800 RPM - 141, 102
    4000 RPM - 137, 105
    4200 RPM – 133, 107
    4400 RPM – 130, 109
    4600 RPM - 127, 112
    4800 RPM - 127, 116
    5000 RPM - 126, 120
    5200 RPM – 125, 124
    5400 RPM – 122, 126
    5600 RPM – 117, 125
    Toyota Stock Cam D=210, Lift=Int .398”, Lift Exh=.385”, LC=110, VL=8/10
    1200 RPM – 95.6 brake tq, 21.8 brake HP
    1400 RPM – 103, 27.6
    1600 RPM - 112, 34
    1800 RPM - 117, 40.2
    2000 RPM - 127, 48.3
    2200 RPM – 137, 57.4
    2400 RPM – 143, 65.5
    2600 RPM - 148, 73
    2800 RPM - 150, 79.7
    3200 RPM – 149 brake tq, 90.9 brake HP
    3400 RPM – 146, 94.8
    3600 RPM – 142, 97
    3800 RPM - 138, 99.7
    4000 RPM - 134, 102
    4200 RPM – 131, 105
    4400 RPM – 129, 108
    4600 RPM - 128, 112
    4800 RPM - 124, 113
    5000 RPM - 118, 112
    5200 RPM – 112, 111
    5400 RPM – 106, 109
    5600 RPM – 98.4, 105
    CC252S (2002 catalog): LC=110, D=204/204, Lift=410/410, LS=110, VL=10/10
    1200 RPM – 99.3 brake tq, 22.7 brake HP
    1400 RPM – 107, 28.5
    1600 RPM - 115, 34.9
    1800 RPM - 120, 41.1
    2000 RPM - 129, 49.1
    2200 RPM – 139, 58.2
    2400 RPM – 145, 66.2
    2600 RPM - 149, 73.6
    3000 RPM - 149, 85.3
    3200 RPM – 148 brake tq, 90.3 brake HP
    3400 RPM – 146, 94.6
    3600 RPM – 141, 96.5
    3800 RPM - 137, 99.3
    4000 RPM - 134, 102
    4200 RPM – 131, 105
    4400 RPM – 129, 108
    4600 RPM - 129, 113
    4800 RPM - 123, 112
    5000 RPM - 116, 111
    5200 RPM – 110, 109
    5400 RPM – 104, 107
    5600 RPM – 96.5, 103
    22RE – Stock, DT header, opened exhaust
    CC252S (new Catalog): LC=110, D=214/214, Lift=420/420, LS=110, VL=10/10
    1200 RPM – 92.3 brake tq, 21.1 brake HP
    1400 RPM – 100, 26.7
    1600 RPM - 108, 33
    1800 RPM - 114, 39.1
    2000 RPM - 124, 47.2
    2200 RPM – 135, 56.3
    2400 RPM – 141, 64.6
    2600 RPM - 147, 72.6
    2800 RPM - 149, 79.7
    3200 RPM – 150 brake tq, 91.3 brake HP
    3400 RPM – 147, 95.5
    3600 RPM – 143, 97.9
    3800 RPM - 139, 101
    4000 RPM - 135, 103
    4200 RPM – 132, 106
    4400 RPM – 130, 109
    4600 RPM - 129, 113
    4800 RPM - 129, 117
    5000 RPM - 123, 117
    5200 RPM – 117, 116
    5400 RPM – 111, 115
    5600 RPM – 104, 111
    PEAK TORQUE @ RPM RANKING
    EB 261C: 3200 RPM – 151, peak tq, 91.8 HP - 5200 RPM – 122 tq, 121 peak HP
    EB 270: 3200 RPM – 151, peak tq, 91.8 HP - 5200 RPM – 123 tq, 122 peak HP
    Put440: 3400 RPM – 150, peak tq, 97.0 HP - 5400 RPM – 122 tq, 126 peak HP
    EB 268: 3200 RPM – 150, peak tq, 91.4 HP - 5000 RPM – 125 tq, 119 peak HP
    CC252S-210: 3200 RPM – 150, peak tq, 91.3 HP - 4800 RPM – 129 tq, 117 peak HP
    Toyota Stock: 3000 RPM - 150, peak tq, 85.6 HP - 4800 RPM – 124 tq, 113 peak HP
    CC252S-204: 2800 RPM - 150, peak tq, 79.7 HP - 4600 RPM – 129 tq, 113 peak HP
    PEAK HP @ RPM RANKING
    CC252S-new: 3200 RPM – 150, peak tq, 91.3 HP - 4800 RPM – 129 tq, 117 peak HP
    CC252S-old: 2800 RPM - 150, peak tq, 79.7 HP - 4600 RPM – 129 tq, 113 peak HP
  6. Xs5875
    Xs5875 Addict
    Greenville, Ga
    =confusing to someone asking for what cam to use.
  7. jetas
    Plus those are numbers for a RE, the OP said 22R
  8. SloPoke
    SloPoke Member
    93 standard cab dx
    Xs55875:
    It may be confusing but it's proper info. Besides, the OP can't expect someone to make his decision for him. He needs to educate himself and make the best decision for him. No better way to educate yourself than with accurate info.
    There are other cams out there than LCE you know.
    Jetas:
    22R or 22RE makes no difference to the cam. The same cam is used in both engines. The numbers may be slightly higher with FI than with a carb.......but it's still good info for him to use to make his choice. Besides, you didn't offer him any help or info. You only chimed in to incorrectly "correct" me.
  9. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    Just a thought: before buying a cam for a 22R head, why not get a 20R head first? 20R heads are supposed to flow better.
    Unless the cams are interchangeable between the 20R and 22R heads, then it doesn't matter...
  10. SloPoke
    SloPoke Member
    93 standard cab dx
    The same cams fit the 20R/22R/22RE & 22RET.
    The 20R head will increase his compression ratio though. :waytogo:
  11. jetas
    I know nothing about Cams so i dont have anything to add. I was looking at this thread to hopefully learn something. But posting info that isnt going to give whats needed for the engine at hand is kinda useless and just as good as peoples opinion.
    Dont mean to offend you, just my .02. Now lets get back on topic
  12. SloPoke
    SloPoke Member
    93 standard cab dx
    No offense taken. I enjoy some good banter......but the info does go with his engine. The method of induction makes no difference to the cam.
  13. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    if using a 22r Early engine with 22r hemi head -the 20r head will have same compression ratio. will need dome piston if not already equipped.
    using a 22r late (laser block) -20r and 22r hemi head will decrease comp ratio
  14. NotAvailable
    NotAvailable Addict
    I would rock a small cam. Something like ted sells. 270/430. Something to give u a little more power and shift ur power band a little up since our trucks hit peak torque at a relatively low rpm. Roughly 3k most are at max torque.
  15. SloPoke
    SloPoke Member
    93 standard cab dx
    :waytogo:
    A 20R head on a 22R pre-laser block raises static compression and will produce more power through the entire RPM range than any cam. (using domed pistons and adjustable cam gear) Oversized valves in a 20R, a port/polish, and nice header can almost double intake cfm. (note: even the "oversized" 20R valves are smaller than stock 22R valves) The 20R intake runners have a straighter shot so there's less restriction for the air charge to make it to the cylinder. Edit: the 20R intake ports are smaller so this increases velocity into the cylinder and increases low end tq)
    Even with these mods, it's still never going to be a powerhouse.
  16. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    .... not to poke at a dead horse, or get off topic but..... i was saying that because the hemi chamber of the 20r and early 22r heads are hemispherical- there is less compression, due to the larger combustion chamber. but the newer 22r/re head with the "pear" shaped chamber- has a higher compression, due to the smaller combustion chamber ......
    correct?
    now i understand of course, all this goes out the window once crank, rod, and/or pistons are changed.
  17. SloPoke
    SloPoke Member
    93 standard cab dx
    Yes, that would be a correct statement BUT.....85 and later 22r/re heads (with pear shaped exhaust ports) will not work on the early blocks without swapping pistons.
    The early blocks are roughly a 1/4" taller (.19") than the later blocks and the pistons stick up more above the top ring than they do on later blocks. This raised portion of the early pistons will contact the 85 & later heads when used on early blocks.
    The early blocks used a 98 link timing chain due to the taller deck heigth where as the 85 and later blocks use a 96 link timing chain due to the shorter deck heigth. This poses another issue when trying to use later heads on early blocks.
  18. eighty_D
    eighty_D Member
    Fairbanks, AK
    '79 SR5 2wd lwb
    All those cams gnarly listed are way small for a street truck.
    From my research 20R heads have a slightly smaller cc volume (80cc vs 82cc) and the slight reduction in chamber bore size 89<92mn adds a little more squish as well.
  19. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    I have a comp 280 (or maybe 282) in the hybrid and it's big time mild. Truck idles at 700 just a smidgin rough, seems to run out of steam around 6 thousand, but that could also be the induction.
  20. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    I had a rv3 cam in my quite built 22r, a little more agressive then a stage 2.. it ran pretty hard til 6k and had a good idle..
