Rebuild
Discussion in 'Engine/Drivetrain' started by fatsam2010, Dec 6, 2012.
  1. fatsam2010
    fatsam2010 Member
    86 toyota pick-up base
    This summer I'm going to rebuild my 22r and I'm looking at the street short block kit from lc engineering, my question is, I'm going to be reconditioning my block assuming its whole and if I wanted to bore out the cylinders to get them in good shape would oversized pistons work fine with the rest of the kit? Any help is appreciated, thanks!
  2. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    lc techs
    You should talk to the texhs over at Lc.They are real cool snd helpfull with stuff like that.aThey will give you the best advice for your application.
  3. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Lc makes great stuff if your going to hone your cylinder walls say 20 or 30 over they'll proably have those pistons in stock with the recommended ring set . And the piston size won't have any effect on the bottom end assuming your getting there rods and crank
