rearends
Discussion in 'Suspension/Chassis' started by pig rig, Jul 7, 2012.
  1. pig rig
    pig rig Enthusiast
    bow washington
    I need to go with a narrower rearend in my 88. so Im seeing that the 89-95 have two different widths can I get meassurements from drum to drum at the wheel mounting surface and what options you have ie; 4spd, 5spd, std cab, excab, engine ect. I'm trying to get an idea what truck I'm looking for so if I need to buy a whole truck I can get the right rear end
    thanks
  2. blt4drgn
    blt4drgn Enthusiast
    bloomington ca
    94-02ish toyota pickup
    from what iv come to understand is that they get wider through the years, the 96-04 tacoma is bigger than the 89-94 and the 89-94 is bigger than 84-88 i believe and so on. so your gonna want to go with a model or two older. i kno when i had my 02 tacoma i ran a 91 and on my 94 which is my current truck it has an 86 rear end in it hope this helps
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Not exactly sure on how much older they go but my 76 and 78 long box trucks both came stock with 53" wide housings with an 8" differential.
  4. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    86 and older is the way to go
  5. blt4drgn
    blt4drgn Enthusiast
    bloomington ca
    theres a big difference in em cause i believe the tacomas are 60'' from what i was told its 1 1/2 - 2 inches smaller in older models
  6. Gadgedizzle
    Gadgedizzle Member
    Northern California
    92 Toy 2wd Reg cab SB Corvette LT1 6-speed.
    AFAIK, The 2wd from 79-95 are all the same width. The only thing that changed was the pinion depth from the axle CL between the 7.5" and the 8". From what I'm told, the 8" requires a Driveline that's ~1" shorter than a truck with the 7.5". also, the 2wd and 4wd use different length axles since the 4x frame is wider than the 2wd and over all track width is wider on the 4x. Makes sense to me.
  7. notabmw1
    notabmw1 Member
    Annapolis, MD
    61 Morris Minor, and Classic Mini Coopers
    The rear I pulled out of the 86 measures in at I believe 55" drum face to drum face. If you were local you could have it for $60 if that is what you needed. I needed a 52", so I just narrowed a ford 8.8 rear.
