Rear motor mount / vibrations help??
Discussion in 'Engine/Drivetrain' started by Juicyy, Sep 19, 2015.
  1. Juicyy
    Juicyy Member
    Norcal
    1993 single cab 22re 5sp rwd
    hey all,
    i've done a bit of work on my truck with lowering it and all, and while i was under the beast i noticed my rear motor mount that holds the transmission up was a little "loose", or the big center knob thingy was able to spin freely. i thought "gee, it's not supposed to do that" so i cranked it down a bit until it was snug, and now when i drive, i get vibrations across the transmission tunnel when i take my foot off the pedal in 3rd gear at 40 mph to drop to 35mph. i'm also getting a bit of "clutch chatter" or the like when i start out in first.
    did i tighten my rear motor mount too tight? is it supposed to be loose? is it supposed to float over the rubber bushings?
    for reference, my truck is a '93 base 22re with 130k miles and probably never seen much maintenance work. i also looked in the graciously uploaded FSM by nathan buchannan, and couldn't find anything on what the specs are for standards of operation.
    help! :brickknock::brickknock::brickknock::brickknock::brickknock:
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    If the only thing you changed was the preload on the trans mount from pre vibration to now then yes that would be a solid guess as to the culprit.
  3. Juicyy
    Juicyy Member
    Norcal
    thanks WhiteTrash, this is true enough, but does anybody know what the service specs are? is it supposed to be tightened down all the way so it holds against the bushings, or does it float above them? do i just have blown bushings and need to replace the rear motor mount?
  4. White Trash
    Eastern WA
    I believe there is supposed to be a bit of float in the mount and by tightening the bolt you removed it. Another thing to consider is the tip of the bolt could be up against the transmission mounted plate transferring vibration between the chassis and drivetrain.
