rear end blown...Can't find a new one. need help!
Discussion in 'Engine/Drivetrain' started by toyacht420, Nov 26, 2014.
  1. toyacht420
    toyacht420 Newbie
    Lebanon, CT
    93 xcab V6 3.0 4x4.
    I have a 93 toyota pickup 4x4 V6 3.0 Xcab. The rear end blew a few months ago and I cannot find a stock replacement for it anywhere in the country apparently. It had 4.56 gears with ABS currently. Can anyone help? I wouldn't mind switching to a ford rear if anyone has a suggestion.
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Are the ABS sensors in the axle housing at the ends or on the 3rd member in the center? If they're on the housing then any generic V6 automatic equipped 4runner will have the 3rd member you need. I'm running one in my auto x truck right now actually. :D 4.56's are a riot in a 2 wheel drive truck. :D
  3. toyacht420
    toyacht420 Newbie
    Lebanon, CT
    93 xcab V6 3.0 4x4.
    There is on sensor on the top of the drop in carrier. The truck is a 5 speed.
  4. White Trash
    Eastern WA
    Pickups with abs aren't all that common. Your best bet would be to pull the 3rd and have new gears put in.
  5. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    yup, like the white trash said. might just be cheaper to get a 3rd memeber/gears from a junk yard and rebuild ur stock.
  6. White Trash
    Eastern WA
    If it wasn't for the abs ring being in the 3rd member it'd be a simple deal to find a factory set of 4.56's to drop in. That's the only reason I'd recommend getting a rebuilt diff. There are plenty of vendors that will build a 3rd member for $4-500.
  7. SloPoke
    SloPoke Member
    corner of 33rd & go to hell
    93 standard cab dx
