rear drop options
Discussion in 'Suspension/Chassis' started by ToxicToyz, Feb 19, 2011.
  1. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    which method would be better for dropping the rear of my 88 pickup, lowering blocks or lowering springs? Which one gives a better ride quality? I heard that using blocks isnt safe because the farther the axle is from the leaf springs are the more the axle twists when accelerating or braking.
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    best *ideal* method would be springs. ive used blocks though and never really had issues in either sense.
    blocks are cheaper and easier to do but springs dont cost that much more. just depends on how tight a budget you have.
    if you want to go lower than 3 inches with a block, i will suggest using springs for those first few inches. this will lessen the amount of axle wrap. going with anything above a 3" inch block to lower the back will result in more noticeable wrap. that however also depends on how hard you drive the truck.
    how low are you looking to go?
  3. jetas
    you could do drop leafs and blocks to get u a total of 5-6" closer to the ground
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    On my 88 when was static dropped, I used 2'' dropped springs, around $140 & 2'' angled blocks,. Rode great, but would the 3rd member would hit the bed bottom.
    Notch was installed earlier than planed,problem solved!:cool:
  5. spanks_4
    spanks_4 Enthusiast
    Denham Springs, Louisiana
    3" blocks, pulled middle leaf, flipped lower leaf, pulled bump stomps. Never had any issues with it at all. Remember these trucks aren't pushing massive amounts of power.
  6. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    i was thinking of using 4 inch blocks, but now i think ill save up to get 2" drop leaves and use the 2 inch blocks i have on right now.
  7. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    or should i use 3 inch drop leaves and a 1" block?
  8. jetas
    the drop leafs give you about a 2-3" drop. from what ive read people had have different results
  9. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Just go to a spring shop and see if they can dearch yours. Might be a little cheaper considering shiping. Thats what the oahu guys was doing. De arch them 3-4" and then throw a 3" block inside
  10. planemos
    planemos Toyotaholic
    British Columbia
    I did just that. 3 inch block and my stock springs de arched. I was very happy with the drop. my tires tucked in the rear. I had no problems with that setup. Oh and I had air shocks too though. They limited the travel a lot cuz they were so stiff.
  11. SD YOTA
  12. 915toy
    915toy Member
    whats a good site to get lowering springs/blocks???
  13. oahu grown
    Hawaii
    92 Extra Cab
    Grab blocks from beefed taco. Hes on here.
    And SD is right too though, how low you like go?
    Probably gotta check for bed clearances and stuff like that which SD would know about
  14. ToxicToyz
    ToxicToyz Addict
    HI
    88 longbed
    I was looking to go maybe 3inches in the front, but in the back i may need to go at least 5 inches because when i got my truck the back was sitting about 2 1/2 to 3 inches higher than the front.
  15. six7one_KDR
    six7one_KDR Veteran
    From Thee Island of GUAM,Live's in WASHINGTON / NO
    1976,1979,and also YES a 1973 HILUX
    heres my 79 with all the rear leaf springs on with a 3" drop block
    now here it is with the the same 3" drop block with the middle leaf spring eliminated "took of the middle spring" and lowered the front more and reset the t-bar,tucked it in the frame.
    hope this might help you a bit.....:thinking:
    post sum pix of your build brothaman...
  16. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    i went yesterday to go see how much it would be to drop my mini and i was trying to get 4 inch block but dude said they illegal? was he foreal?
  17. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    No not that i know of but then again any mod you do to your truck is illegal
  18. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    lol he said 550 for a 2-3 inch drop all around but i want more drop is that too expensive? should i just pull the middle leaf, bj flip and crank torsions instead?
  19. Dgerfan55
    lake elsinore CA
    94 pickup
    Well what all is he going to do? I mean if that includes the drop spindals up front and drop leafs in back and labor then i think thats a far deal cause those parts alone cost that
  20. lowplz
    lowplz Member
    Hayward, CA
    87 longbed
    he is gonna do shocks crank torsions and 2 inch blocks in the rear. come to think of it i might just do it myself
