RAV4 Wheels on 80 2wd (stock ride height)
Discussion in 'Wheels/Tires' started by wtsane, Feb 6, 2014.
  1. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    my 1980 came with a set of 14 inch Keystone mag wheels (very 80's, stick out about two inches from the fender lip). I have a set of RAV4 16X7, 4.5x5 wheels which I think will fit, but am worried about the offset. Is there a site somewhere which will do the math for me?
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    What's the ET number of the back of the rav4 rim? If its between +30 and +50 mm they should fit good.
  3. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Research says 35-42mm "high positive" offset. The wheels only have the following "jj16x6jjdot topy 7 01 97 2.6" Thanks for the input.
  4. standardbyker88
    lynnwood, wa
    I often use eBay to find the replacement rims for things, then read what they state the offset is if I either don't have the wheel to look at (new rim choice research) or it doesn't state it (many OEM rims don't). That offset should work fine for your truck stock or dropped.
  5. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Thanks, I just had the seats recovered, and splurged on a NOS dash pad, so the tires will have to wait a bit, but the information is much appreciated for when the time comes.
  6. wtsane
    wtsane Member
    Panhandle Florida
    1980 SR-5 4x2
    Update: Rav 4 wheel will not bolt right up, the center hole is too small. I want 15 or 16s which will bolt up without spacers, anyone have a suggestion?
