Radiator
Discussion in 'Engine/Drivetrain' started by Dgerfan55, Aug 22, 2011.
  1. Dgerfan55
    Dgerfan55 Grand Toyotaholic
    lake elsinore CA
    94 pickup
    Hey Toy Peeps......:meemee:
    Just wondering what these are on the bottom of the radiator?:thinking: Could i just plug them? Or will i have problems?:shrug: Thanks in advance.:waytogo:
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    For if you have a automatic,trans cooling lines!:cool:
  3. atrax
    atrax Newbie
    socal 323-818
    73'toyo hilux
    if your driving standard, those lines are not necessary. plug them if you are driving stick
  4. Dgerfan55
    lake elsinore CA
    94 pickup
    So i can plug them and everything will be ok
  5. Dgerfan55
    lake elsinore CA
    94 pickup
    Also what should i plug them with?
  6. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    brass plug
    They sell those brass plugs. Unscrew those nipples and bring it in to match threads with a plug. or a hose with a bolt in the end and a hose clamp but thats high pressure. Maybe double hose clamp to be safe.
  7. 90ls1toy
    90ls1toy Member
    AUGUSTA GA
    90 EXTRACAB SR5
    Most aftermarket manufactures build universal replacement radiators because it is cost effective ie you can have one part number that is good for both autos or manual transmissions.If you have a manual transmission it is not a must that you plug the fittings. It is not going to change the performance of the radiator or leak. The idea of plugging the radiator is to prevent foreign material such as dust from entering the cooler just in case you want to use it later with an auto.
  8. thundering02
    thundering02 Addict
    Fenton 63026
    Use it for an oil cooler instead.
  9. Dgerfan55
    lake elsinore CA
    94 pickup
    So a rubber cap would do? Nothing will leak? Or should i just cap them off to be safe like Melessohomegrown had mentioned? Thanks again guys
  10. 90ls1toy
    90ls1toy Member
    AUGUSTA GA
    90 EXTRACAB SR5
    As stated before you can leave them as is and it will not change anything other than the looks of it. It will not leak any thing.
  11. Dgerfan55
    lake elsinore CA
    94 pickup
    Thanks guys for the help
  12. jetas
    Yeep ive installed one n just left the rubber caps on it and never leaked. Im assuming it runs seperate from the coolant
  13. IronNam
    if you plug it off you can die!
    hahahaha yes, it is seperated from the rest of the coolant's flow..
    +1 on thundering02, use it for oil :D
  14. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    If it bothers you that much,cut them off tight to the radiator ,& close off with silicone or something.
    No coolant is there ,the trany fluid would move through a lower sealed off area to be cooled!
    Check by filling with water !!:cool:
  15. IronNam
    I promise you it's separated, otherwise i'd have ATF in my coolant by now!
  16. jetas
    Or coolant in ur atf
  17. Dgerfan55
    lake elsinore CA
    94 pickup
    Nice. Sounds good guys, thanks for all the help. Im going to put it in tommorrow or this weekend.
  18. IronNam
    tomorrow! you can easily do it. Pliers are needed for those huge OEM hose clamps...
    10mm sockets for the shroud. plier and 8mm wrench (or 10mm?) for the fan. should be done real quick.
  19. Dgerfan55
    lake elsinore CA
    94 pickup
    Yes i know but i had to watch my kids why the wife went to work and i also had a game at 8 tonight
