radiator options without plastic tanks
Discussion in 'Engine/Drivetrain' started by warbird, Dec 31, 2014.
  1. warbird
    warbird Member
    any options for a 93 22re Manual...i hate these stupid plastic tank rads.... i have seen a couple in pics that seem to be brass/copper...ive also seen the polished aluminum ones....i am looking for the brass/copper option...any ideas on where to get one of these?
  2. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Radiatorbarn.com
  3. warbird
    warbird Member
    ya nope...evrything i find on there is plastic tanks.....maybe a retrofit from an older model toyota P'up is what im seeing people use?
  4. jetas
    Look for an aluminum tank with similar dimensions
  5. myles66
    myles66 Newbie
    little rock, AR
    1990 toyota hilux 2x4
    an aluminum tank will be alot better IMO than a oem brass tank. but dont get cheap chinese junk.
  6. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    Ebay has some good aluminum ones, that's where I got mine. Mine was a champion radiator and only cost me about$150 shipped but it wasn't a Chinese crap
  7. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    was that a direct fit (made for toy) or did you just go by dimensions?
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
  9. White Trash
    Eastern WA
    Thats too bad. The last one I bought from them was copper/brass 3 core unit for $111 to my door. They were always my go to vendor.
  10. first80toyota
    Pacific Northwest
    '77 Hilux
    It wasn't direct fit for my truck but it was for a 92 toy pickup with a 22re.. as far as I know the only thing different for v6 version was its 3 core instead of a 2
  11. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Got mine from Napa for like 112 bucks as I recall. All steel radiator. But that was also a couple of years ago. :waytogo:
  12. myles66
    myles66 Newbie
    little rock, AR
    thats pretty good to know, iwonder if thats wth most v-6 aftermarket rads. do all bolt holes line up?
  13. first80toyota
    Pacific Northwest
    '77 Hilux
    I can't say for the newer mtrucks, but it didn't exactly in my 77. Width was perfect, so I used the top two holes and redrilled the bottoms. They were only off like 3\4"
  14. aseq
    aseq Member
    CA Bay Area
    87 2wd, Carb, Longbed xtra cab
    I just ordered one from LCE and installed it the other day. It took all of 50 minutes and I was taking it easy, 22Rs are so easy to work with.
    After a test drive or so I can't say much except it cools as well as the one before (but that probably has more to do with the thermostat which opens quite early, needle is close to the lower line marked C). The one from napa is exactly the same, both are CSF, 3 core all metal (copper/brass). I had an all aluminium one before (some no name from China bought from autopartswarehouse.com), it lasted about 80k miles and developed a small leak, might just fix it to keep as a spare.
    Heavy Duty Radiator 22R/22RE 1983-1995 Pickup & 4Runner With Cap, LCE: Heavy Duty Radiator 22R/22RE 1983-1995 Pickup & 4Runner With Cap
    Radiator NAPA, ATM 1532401 Altrom imports: NAPA AUTO PARTS
    NAPA's altrom import parts often are OEM and of good quality, priced a bit higher than their regular stuff. LCE's OEM parts are pretty much the exact same parts. In my opinion you can't really go wrong either way. I prefer LCE for online shopping since they ship fast, NAPA is best when I want or need to go to a physical store.
    The price is about the same for both, LCE asked $279 at the time of ordering, napa may be $10 or so cheaper (it appears to be on sale as of 03-08-2015). I suspect it's gonna last a while and cool well since it is 3 core, which I believe is meant for heavy duty applications such as towing. I read the original one for regular trucks has 2 cores. Lots of cooling capacity left over under normal circumstances. :)
    I kind of like the shiny painted look, but that's soon gonna fade and get dirty. ;-)
