rack and pinion
Discussion in 'Suspension/Chassis' started by boris93, Oct 7, 2010.
  1. boris93
    boris93 Newbie
    ct
    93 strd cab
    has anyone ever tryed to put in rack and pinion steering in there truck?:shrug:
  2. tineye
    tineye Newbie
    Virginia
    '94 Toyota DLX 4x4
    I'm sure someone has done it, remember, anything is possible... just takes money and time.
  3. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    I almost did.... but went a different route in the end. Im not sure if anyone has.
  4. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    i put it in my hilux. it's custom suspension, but is all based on the 84-88 toyota frontend. it works perfect with no noticable toe change through out the travel, but has to be custom mounted including the steering linkage itself. it's a flaming river unit, 71/72 ford pinto, narrowed 5" by flaming river, cost about $360, not including the heims to make it mate to the spindle.
  5. planemos
    planemos Toyotaholic
    British Columbia
    What a pretty picture :applause:
  6. boris93
    boris93 Newbie
    ct
    93 strd cab
    what about the linkage?
  7. burnzya
    bodied 73 hilux
    my stock hilux steering had a rag joint at the firewall since it had rear steering so it's a little different. but you can cut the stock shaft a little out of the firewall, and add a universal joint like this.
    http://www.speedwaymotors.com/Sweet-Mfg-Steering-U-Joints,2031.html
    part # 91032234
    then use a piece of 3/4" cold rolled steel stock and weld this on the other end
    http://www.speedwaymotors.com/Steering-U-Joints-9-16-26-Spline-Mustang-II-Manual,31385.html
    i'm using mk3 supra spindles so i drilled them out to 1/2", and used these heims:
    http://www.speedwaymotors.com/Male-LH-Rod-End-With-Studs,24259.html
    part # 1750325
    i made some custom adjusters using some 3/4"x.156" 4130 chromoly tubing from
    www.aircraftspruce.com
    i tapped them with rh thread on one end, and lh thread on the other so that they adjust just like a stock unit.
    here is the couple pics i actually have of the steering linkage
    you can see the plate that bolts to the firewall to see where the first joint would go
    column installed
    the steering is incredible smooth with no play at all. it's very involved work to make it work, but not too hard.
  8. burnzya
    bodied 73 hilux
    oh and i completely removed the shaft from the column to weld on the first universal.
    and my firewall universal is actually out of a 5.0 mustang. i didn't know i could buy weld on universals until i had already used the mustang universal lol
  9. burnzya
    bodied 73 hilux
  10. boris93
    boris93 Newbie
    ct
    93 strd cab
    thanks man.
    i just read ur thread on the hilux, where did u get the ball joint stuff?
  11. burnzya
    bodied 73 hilux
    i posted in my build thread already but i'll post it here for the general population who might want to do it. lol i got everything at www.speedwaymotors.com
  12. boris93
    boris93 Newbie
    ct
    93 strd cab
    did u get the chrystler type, do you knowif that is the same taper and size for the pickup spindle?
  13. stabfab
    stabfab Newbie
    Hercules, CA
    1989 Toyota PIckup
    I made a kit.
    Young92Pickup likes this.
  14. BatryOpratedBoy
    BatryOpratedBoy Enthusiast
    Fresno. =(
    Brave Little Toaster (Diana) and Salsa Verde (Traction Control)
    Have you cycled it fully? Any bump-steer? Does the Mustang II rack need to be narrowed?
  15. stabfab
    stabfab Newbie
    Hercules, CA
    1989 Toyota PIckup
    I'm not sure what cycled it fully means, but you get 2 full turns in each direction. Turning radius is about the same as stock. I've done 2 kits now on trucks with 2" drop spindles and slightly relaxed torsion bars and that seems to be about the limit as far as not having bump steer. Any lower and you'd have to get a bump steer kit for a Mustang 2 and probably drill and flip your tie rods to the bottom.
    I've been running mine for about 3 months and I can say it's a significant improvement in overall feel and response. You can also drive down the highway at 80 with one finger on the wheel and it won't try to change lanes when you catch a groove. I've gone pretty hard in the mountains, hit many turns at speed and haven't experienced any bumpsteer yet. The tie rod pivot angles are about identical to the Toyota. You do have to narrow the inner tie rods by 2 inches so the overall width is 46".
    Here's a video:
  16. Erik Beeman
    Erik Beeman Member
    Oregon City, OR
    1992 Toyota Pickup
    I'm from Concord, live in Oregon now. Coming back for a visit in 2 weeks, would be interesting in checking this out.
    I've got a sbf swap, I wonder if this would fit. Looks like the shaft angle would run into my headers.
  17. stabfab
    stabfab Newbie
    Hercules, CA
    1989 Toyota PIckup
  18. BatryOpratedBoy
    Fresno. =(
    If there was a way I could have this, and the Corolla or Yaris EPS, I'd be such a happy critter. I'm glad you made this.
  19. stabfab
    stabfab Newbie
    Hercules, CA
    1989 Toyota PIckup
    Thank you! I thought about it, actually tried for weeks to get a Yaris rack to work but there were way too many variables. I don't see why you couldn't use a Mustang power rack though and then just source a few fittings and hoses to make it work with the Toyota pump. I made the Lexus power steering stuff work on my wife's 2JZ swapped Celica by using a 3.0 pickup pressure line. It wasn't too bad. Maybe that'll be my next objective.
  20. Justin Danger
    Justin Danger Addict
    Bay Area Peninsula
    I've got a turbo that takes up more room than the stock 22re manifold, would that cause clearance issues with the new steering shaft on your setup?
