Quick release steering wheel?
Discussion in 'Off Topic' started by 86extTURBO, Jan 23, 2011.
  1. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Does anyone know of a company that makes them for the 84- 88 trucks?
  2. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    I've really been looking into one for my 89 but not much luck either. Any info guys???
  3. TheLoLux
    TheLoLux Toyotaholic
    Simi Valley, CA
    no one make one for the toyota, you have to weld the spine to your steering shaft
  4. Comrade_Charlie
    Comrade_Charlie Veteran
    Rock Hill, SC. Charlotte, NC
    1973 Hilux
    Cant buy one for a honda/mazda/nissan, whatever, and a toyota to honda adaptor if that even exists?
    Would be nice, im a tall guy and i look funny getting in and out of my truck, gotta insert one leg first
  5. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Isn't tht how everyone gets in? One leg at a time. Never seen someone go both legs at once lol
  6. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Well I've got tilt but my friendsvhave been getting their lowered cars jacked lately
  7. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Does the supra steering wheel fit the trucks. Cuz nrg makes a supra quick release
  8. Comrade_Charlie
    1973 Hilux
    Haha I mean before I get in the truck I have to like slide my leg under the steering wheel some weird way and like fall in the truck. im 6'5 so.
  9. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Haha can you take video of this event and post it?
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Haha I'm just ****in with you man. I'm almost 6'4" I feel your pain everyone makes fun of me cause i drive a mini
  11. Nook
    Nook Addict
    oregon
    Any of the quick release hubs should fit your truck, they are all a universal fit, I,m not aware of any that are splined for specific applications.
    NRG makes several different styles, the paddle lever style or pull ring ones add about 3 to 31/2" length moving the wheel closer to you. They also make a short version that has a twist ring, personally I don't care for those, hard to align the wheel and turn.
    I run a Tekniq street version on my rig, has a double pull knob plus its keyed so you can lock the wheel on, works fine and its only about an inch thick.
    You need to use an adapter hub like you would use for any custom wheel application, then depending on the hub and bolt count and size,, you can either bolt the quick release directly to the hub or use an adapter plate, plus the wheel has to have the correct bolt count and size to fit the Q/R, most use the Momo, Sparco 6 hole bolt pattern.
    No need to weld a race style on unless your not concerned with looks, horn, turn signal cancel, or being able to remove anything from the column at a later date.
  12. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    ^ yea, look for them for toyotas in general. most toyotas have the same shaft spline. there's at least two people on here who have OE supra wheels on their trucks on this site.
    smaller non-release wheel is on my shopping list when I finally find a job (going to school so not a huge huge issue...yet). I'm 6-4 and my problem is more knee space while driving the std cab :p
    Guess who had to work on all the fiats, miatas, and minis at the shop I used to work at just so everyone else could watch...
  13. Nook
    Nook Addict
    oregon
  14. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    Ok thanks nook I was trying to look up spline sizes last night but I couldn't find anything and how does that teqnik work for you I was thinking about that one because it has a key but I like the low pro of the nrg.
  15. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    I just need to buy a momo wheel now I wish the one on my supra never broke.
  16. Nook
    Nook Addict
    oregon
    The Tekniq Q/R works great, nice and tight, actually its about as low profile as you can find, the NRG is about 3.5" the slim NRG is about 1.5", the Tekniq is right at 1". The key option is fine, use the key to unlock to remove the wheel, don't need it to put the wheel back on, that way someone can't reach in and pop the wheel off without the key. The Tekniq is a bit spendy but nice quality.
  17. 86extTURBO
    86extTURBO Veteran
    CA
    1986 ext cab Turbo
    i really like how sleek the nrgs are. i wsih i could run one with the stock wheel
  18. IronNam
    dude I do a full running start and jump in the air. mid aerial I do a 360* twist and left hand grabs the interior door handle. aim the legs for the floorboard and as they reach it, the right hand gets the keys into the ignition. upon sitting down, at the end of the intense aerial, i turn the key to start the truck.
  19. ttimpain
    ttimpain Newbie
    I spent last night trying to find the key size, but I can not find anything, what do you think teqnik work for you, I considered this one of the issues, because it has a key, but I like the low pro-NRG.
  20. Nook
    Nook Addict
    oregon
    Sorry, guess I,m just not clear on what your asking? the key size is just a standard barrel key, yes, the Tekniq worked for me, whats the issue because it has a key? it locks on so someone can't reach in and pop the wheel off or you can't accidently pop it off while driving. The NRG thin version is fine, I just personally didn't like the twist action to install and remove the wheel.
    Also some of the thin models, you have to watch the steering shaft length, the shaft may stick out too far needing a spacer to install the unit.
