Quick question
Discussion in 'Suspension/Chassis' started by -85yota, Mar 27, 2013.
  1. -85yota
    -85yota Member
    I have 205/70/14 wheels all around ima drop the back should i get smaller tires also the front is dropped with torsion bars i want it lowered the same from the back, it has 4 leafs i wanna pull out 1 nd install the 3 inch block, can some someone post pic on 14's lowered from the back just blocks thanks if u can
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    70 series is still a bit tall for any kind of substantial drop.... You will at the minimal want a 60 or 55 series tire on those 14's so the front dont rub and hit the top of the fender well.
  3. 1982rn34
    1982rn34 Addict
    Bay Area 408
    1982 SR5 RN34
    Tires sizes are very limited these days, so a 60 series 14" tire would be your best bet. There is a 195/60-14 T/A available & affordable. I still remember when BFG Radial T/A's were available for the 13" & 14" wheels in a 50 series. There is a 205/55-14 tire on the market, but is very costly ($150.00 ea).
    Good luck with the lowering!
