So I am rebuilding the 93 and need to replace the front lower arms, I have also decided to redo the whole steering linkage and bushings. When I look at front end parts online they get listed seperately 84-88 and then 89-95... I thought the front ends were the same 84-95 on the 2wd same arms and steering linkage right???
I'm not sure about the steering arms, but I do no that the LCA's are different, it's where the ball joint bolt to the arm, its a different bolt pattern.
DJM has 3" drop control arms for 89-95. You may be thinking of the spindles. I believe the spindles (i have belltech) can be used on both models.
I thought the control arms and spindles were the same 84-95 the DJM LCA drop arms are listed as 88-96... ya OK??? their instructions talk about the ball joint holes being 10mm in older trucks and 13mm in newer.... nice really makes sense DJM!?
well....thats the same people who told me i must have too much power if i broke 2 sets of 4" blocks. i said its a 96hp truck that cant even get traction. ive never been a huge fan of them. but havent heard many complaints.
