Qs about driveshaft
Discussion in 'Suspension/Chassis' started by krazedprof, Oct 5, 2011.
  1. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    so as many as you guys know i have a 302 with a c4 and stock toy rear end. my question is did you guys that bodied your trucks have to notch the cab and the stock cross member for the drive shaft also mine was a 2 piece and now im thinking of having a one piece made.
  2. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Im not bodied and I still had to notch my cab and crossmember cause i want to roll Cali hard. Ive never seen a 2pc shaft on a reg cab truck but I would definetly go a 1 pc with that motor and tranny combo.
  3. RosamondMini
    RosamondMini Enthusiast
    Rosamond, Ca ( So Cal)
    93 Pickup
    i only had to notch my crossmember. The cab isnt touched.... yet
  4. krazedprof
    krazedprof Addict
    iowa
    yeah mine is a reg cab but a long bed too so it looks like i will need to notch it than also what is the pinion angle for these trucks?
  5. Under Construction '93
    Under Construction '93 Addict
    Riverside,Ca
    1993 Std Pickup
    Thats weird... With front up and back all the way down your driveshaft doesen't hit the cab?
    As far as the pinion angle goes, you want to cancel out the angles of the u joints. Find out the degree of the output shaft of the trans and have that same degree on the lower plane at ride height if that makes sense. Im sure you can google images for it to help.
  6. IronNam
    long bed should be 2piece i believe
