pulling the oil pan with engine in place
Discussion in 'Engine/Drivetrain' started by warbird, Dec 28, 2014.
  1. warbird
    warbird Member
    as the title states.... anybody done this? is it possible?
    i have a rod bearing going out and wanting to just slap a new one in to get me by while i build my spare motor...... any input? thanks
  2. first80toyota
    first80toyota Addict
    Pacific Northwest
    '77 Hilux
    What year truck?
  3. warbird
    warbird Member
    sorry ...1993 22re 2wd
  4. jetas
    Can you unbolt the xmember under the engine?
  5. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    You will have to drop the bolt in cross member. Then unbolt the motor mounts. Place a jack under the trans bell housing and then jack the engine up til it stops. This is to allow the oil pump pickup to clear.
  6. warbird
    warbird Member
    if the bolt in cross member is removed what is there under there left to clear that requires the engine being lifted?
  7. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Steering linkage...
  8. jetas
    Wouldnt it just be easier to unbolt the steerinng linkage?
  9. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Yall go ahead with all that...I'd rather unbolt 4 bolts then beat steering components apart all day.
  10. warbird
    warbird Member
    ya know..... i should have thought of that before asking such a dumb question..... thank you for the answer though.... went ahead and dropped the steering linkage since after raising the engine as much as i could the pan would not clear the sway bar .....oh well... only two nuts... now i know, thank you to those that answered
  11. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    :waytogo:
    live and learn. now u know how. i ran into the same issue. but i just wanted to reseal the pan. bearings were fine. i learned the hard way. even just to remove the sway bar is a b!tch
  12. warbird
    warbird Member
    ya. but it keeps gettign worse lol.... one of the headbolts broke off while tryign to remove the head. luckily some is still stickign out of the block ....now if i can just get the head to come off.. (yes i removed the bolt in the front cover) ....so today after work i get to wrestle with that in the driveway with snow and 18* weather.....pretty stoked about that
  13. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    I just pulled my oil pan with the engine and 1 ton sway bar still in place. I dropped the crossmember under the pan and unbolted the idler arm from the frame. That allowed more than enough room to get the pan off without issue.
  14. myles66
    myles66 Newbie
    little rock, AR
    1990 toyota hilux 2x4
    im not sure if unbolting engine is easier or harder, but ive always just unbolted the steering linkage from the frame on the passenger side. its like 3-4 bolts and it just swings down outta the way. if youve got a steering damper, unbolt one side of that too. oh and chock yer front tires if you do it that way.
  15. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    ---@ the stuck head bolt.... how i removed it (from a friends truck) -used vice grip pliers, lock it down super tight, lace it up with some PB blaster, and with a hammer, gently to moderately tap on the top of the broken bolt while trying to work the bolt back and forth. came loose after a few minutes of trying. then when it finally broke loose, i backed it out slowly (still with vice grips) tight and loose and lots more PB blaster.
  16. warbird
    warbird Member
    thanks Taco, I forgot to update that I got the bolt out (with PB blaster and time and a ol'school stud extractor) and the truck is back together and running great
  17. Houa Thao
    Houa Thao Enthusiast
    Sacramento, ca
    91extracab
    I did mine without taking all those parts out. Just remove all the oil pan bolts and take extra time cleaning and putting it back together. It was a PIA, but I did it.
