pulling a leaf
Discussion in 'Suspension/Chassis' started by jetas, Jun 27, 2010.
  1. jetas
    Ok so i put in my 3" blocks a while back but i still wana go lower without spending too much $$$. Ive pulled the middle leafs before but that same damy my pinion bearing took a crap. So i put the middle leafs back in and replaced the bearing.
    Im thinking of pullin the leafs again but i dnt wana have to deal with that crap happening again wen i do get around to driving the truck(its been sitting for 6+ months now)
    What could have caused this to happen and should i even risk doing it again? Im thinking of putting in a 4th leaf but flipped upside down, and add some clamps to flatten out the springs a bit.
    Air shocks have come into my mind aswell.
    what do you guys think???
  2. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I'd just pull it again. Maybe the old one was bad already. I'd think adding another Lea would raise It not drop it even if it's flat.
  3. NotAvailable
    NotAvailable Addict
    if your pinion angle is bad wen you pull middle leaf use a angled block. some call it tapered block. it helps keep your pinion angle
  4. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Ive also got angled blocks, but Im also running a mono-leaf & air shocks too. Im also thinking your pinion bearing was bad before you dropped it so Im thinking youll be ok if you pull another leaf out.
  5. IronNam
    i got those non tapered blocks and removed mid leaf. i did my pinion seal a while back. no leaks so far.
    3"blocks and mid leafs right here.
  6. jetas
    ive been wanting to get some blocks from beefedtaco but i just dnt have the $$$
    I think i am guna pull em again just scared to spend another $60 on another bearing
  7. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    I still think it was bad before you pulled it an once you pulled it you actually noticed it. Maybe some angled blocks like stated before
  8. IronNam
    eh just grab angled blocks.
    Bearing? damn... i only had to tinker with the seal
  9. jetas
    yup the bearings were everywhere. i might have just get the pinion shims.
    Whats the stock pinion angle on these damn things?
  10. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Go to lowes an get an angle finder an set it on the rear end an it'll tell u
  11. jetas
    well getting the angle finder aint the issue. or putting it up to the pinion. just idk if the blocks changed the angle. i dnt think they did simply cuz the axle just got moved straight up. but i could be horribly wrong
  12. loluxprogress
    loluxprogress Enthusiast
    VIC, Australia
    1994 Toyota Hilux 22R
    ive considered pulling a leaf to drop my height, which one is best to remove and how much will it drop by?
    cheers.
  13. jetas
    the middle one. you should only have 3 so yea not too hard to figure.
    youll get like 1" lower
