Projector headlight
Discussion in 'Exterior/Body' started by Radchadtrinidad, Dec 30, 2014.
  1. Radchadtrinidad
    Radchadtrinidad Member
    Anchorage, Alaska
    86 pickup
  2. jetas
    Those arent actual projectors. The just stuck a domed lens in a sealed beam housing. Retrofit is guna be the only option for a projector
  3. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
  4. Staf0s
    Staf0s Newbie
    Conejo Valley
    91 SingleCab
    Light Werkz
  5. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    those are junk and like previously mentioned they are not real projectors. if your smart you can do a full retro for under 200$
  6. IronNam
    ^What Joey said.
    Pilot H4 7x6 headlights (plastic housing, plastic lens) go for $30 on Amazon. Extremely easy to work with, extremely to take apart, and they're a nice clear lens.
    Morimoto A or B stock Mini H1's or D2S's, better than what others offer. DDM sells old **** that's not even tuned and sells them for a stupid high price.
    These will be easiest to install. B-stock has tiny imperfections that doesn't meet TRS's standards, which means a tiny nick or something but most and majority of the guys I know that got the b-stock stuff were extremely impressed when the issues are so minuscule.
    Mini H1 v.6.0 = 2.5"
    Mini D2S v.3.0 (If I'm right, it is version #3.) = 3"
    FX-R 3.0 are either in 2.5" or 3"
    I've heard people liking the H1's over the D2S's but they have a slight more hot spot towards the middle.
    The D2S and FX-R's have quite a bit of width and much more even distribution of light.
    Any of these three would be good, the FX-R's would require a handful of trimming to fit, where as the Mini series are screw in.
    Alternative to the FX-R's are the Maxima's or RX350 non AFS with clear lens up grade. with some tuning these have tons of width and extremely sharp cutoff, along with even light distribution.
    There's a ton of different bi-xenon projectors to choose from.
    You could get an HID projector kit ordered yourself for $250-270, using b-stock, but you will know that your components will be high quality. The Morimoto xb35 ballasts are amazing, look sleek, and mount easily.
    A regular a-stock setup from TRS will sit around $300. Their XB35 series of bulbs are really nice. I had their old regular 5000K bulbs and they were a night pure white, but not as much lumens as an OEM supplier bulb such as Osram (my CBI bulbs are $150-170, and deliver roughly 3400 lumens, just as much as an OEM 4300K bulbs.)
    The XB35 4500K/5500K bulbs put just as much lumens and work well, for a fraction of the price of the CBI's.
    Feel free to ask more questions
    The Retrofit Source Inc
