Project Lo - Lux
Discussion in '1984-1988 Build-Up/Project Threads' started by SD YOTA, Dec 30, 2008.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    but still happy anyways.......
    also have some nice 2wd fenders to slap back on my truck sitting in the garage along with a SR5 tach cluster :D
    anyone need a set of decent 4wd fenders? might also be selling my clear corners since i'll need to buy some 2wd clear corners :rolleyes:
  2. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    lol what are those man ? and yeah I sent your christmas present today, enjoy
  3. lownloud
    lownloud Toyotaholic
    Plains, Montana
    They are Lower control arms . . . Hopefull, I didnt miss your real question Javi . . .
  4. V8_TITAN
    Tampa Fl
    89 std cab
    you did. lol.. but what makes those better then stock ones ?
  5. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Same kind ive got on my 91...if you look at the end of the arms youll see they sit slightly higher-(2 -inches I think) than the rest of the arm. Thats where you bolt the spindle/brake hub etc too & it makes it sit higher up thus lower the front more!
  6. V8_TITAN
    Tampa Fl
    89 std cab
    where do you get these ?
  7. SD YOTA
    javi- these are my new DJM 3" drop lower control arms. they drop your truck 3 inches and retain your current ride quality.
    much appreciated on your christmas present.... cant wait for that to get here as well:D
    SMC- they are advertised as 3 inch.... hope thats what i get out of them.
    javi- i got these from Summitracing.com for $207.xx shipped to my door :D
    combined with the 2 inch belltech spindles i have and a few more tweaks of the torsion bars, i should be riding at a healthy 6-7 inches worth of drop in the front.
    i have 3 inch belltech drop leafs in the rear and will be getting some Beefed Taco 3 or 4 inch steel tapered steel blocks later this week as well.
    this combined will net me around 6-7 inches of drop in the rear.
    if my calculations are correct, i should be tucking the wheel up into the fender line once im done. :D
  8. IronNam
    nice arms
  9. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    my only question is, how the hell are u going to go over a speed bump? make sure to take pics! if my truck doesnt sit low enough i might be doing this as well.
  10. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Look at my truck & youll see how low hell sit...I scrape over spped bumps, but its nothing that Im not used too lol! Oh a SD YOTA after I posted my comment I realized I put 2 instead of 3 inches lol. So your good...youll get the drop your looking for!
  11. SD YOTA
    thanks guys. imma get working on it here in a few. gotta go pick up a few other parts i need.
    frinzo- im having my exhaust cut and tucked up higher and cross member notched to clear above te frame rails just like pictured below..... it'll help allot with the crapping. im also going to ramp my spring hanger for the rear.
    smctoy- its all good man, i figured you typ-o-ed
  12. V8_TITAN
    Tampa Fl
    89 std cab
    yeah I need new crossmembers because mine used to scrape speedbumps when I had my torsions all the way down... anyone make them cheap ? and Alex,I looked on summit and could not find them
  13. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    Hey talk with member Twisted Minis and see if he still makes his crossmember..this is the post with it, just his pics dont come up. but from what i remember this would do what u need.
    http://www.toyotaminis.com/forum/showthread.php?t=525&highlight=crossmember
    If anyone has the pics of his x-member can u please post them up! thanks!
  14. lownloud
    Plains, Montana
  15. Frinzo
    Frinzo Toyotaholic
    Hinesville, GA
    '86 Std Cab
    lol!, thanks Lownloud!
  16. SD YOTA
    yea, i know seth has his x-member and is a seriously nice peice. definate must have if yer going bagged but i still need my stock x-member since it holds up my torsion bars :D
    Javi, here's the link. you really have to look for em..... much like anything on summit..... i typed in the part number from JDM... DJM Suspension CA2855L-3
    link to the arms....
    http://store.summitracing.com/partd...907510+4294839061+4294848363+115&autoview=sku
  17. SD YOTA
    here's what it ended up as of today.
    before anything, i would like to thank my buddies Mike and Allan for all their help. thanks to you guys the time whent by faster and so did the work. thank you... thank you much!
    i guess sometimes, "lower standards" are not so bad at all.....
    LCA comparison. JDM 3" on the right.
    the one issue i did run into after everything was done was.......... how the hell to get the damn jack out from under the truck? [/quote]
  18. IronNam
    lol utilize two jacks
  19. SD YOTA
    yea...... i ended up placing a 4x4 block of wood under the tires then jacked it from the side frame rails....... im gonna have to get a low-profile approach jack cus otherwise my old jack just wont cut it.
  20. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    looks great...I really like how the 4x4 fenders look on that body style truck!
