Problems with shocks
Discussion in 'Suspension/Chassis' started by HIyota, Jun 3, 2012.
  1. HIyota
    HIyota Member
    Hawaii, big island
    1980 toy
    So just yesterday I got air shocks part#ma785 for the front of my80 I cranked the torsion bar all the way down but wen I fill the shocks with air they only go up an inch and a half. Does any one knowwhy? The shocks are Monroe air adjustable shocks can some one please help me I was kinda numbed because it says 4.5 inch travel and it's no where near it
  2. clark
    clark Member
    Honolulu, HI
    '80 3/4 ton Long Bed 20R
    maybe your air compressor isn't giving enough pressure
  3. ResidentG33k
    ResidentG33k Enthusiast
    West Covina, CA
    88' 22R 2WD Single Cab
    I agree with Clark. Probably need to adjust the PSI on your Compressor to match the amount of PSI required to air up the Shocks.
  4. HIyota
    HIyota Member
    Hawaii, big island
    1980 toy
    Li used two compressors so I don't thing it's that they both pumped to 150 but don't give the shocks full extension
  5. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Have u tried lifting the truck on jack stands and then fill the shock and watch the travel ?
    Or is there any tension on the torsion bars at all
  6. HIyota
    HIyota Member
    Hawaii, big island
    1980 toy
    Actually I seethe torsions as low as I could go before the fenders touch the tire so that way wen I park I can slam it and wen I drive I can lift it all the way up but it only goes like half way ... Could t be that there is to much weight?
  7. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    I dunno I've never had air shocks . Don't think they are designed to lift like a air cylinder or bag so I would try lifting the weight off the truck jack stands filling them up with some good air pressure all the way . Set it down and if it's higher than before than yea they can't lift the front on there own
  8. HIyota
    HIyota Member
    Hawaii, big island
    1980 toy
    Ohk thanks bro that got me thinking they are made to level heavy loads so sence it's in the front and not the back that could have pilot alot of weight
  9. TDS909
    TDS909 Veteran
    ONTARIO
    1992 st cab
    air shocks
    All the air shocks are supposed to do is level the truck out with weight in it
