Post your suspension set-up.
Discussion in 'Suspension/Chassis' started by 89-ED7, Oct 20, 2012.
  1. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    Post your suspension set-up so others can use yours as a guide when choosing there's. Post these things...
    Front-
    Rear-
    Wheels-
    Tires-
    Additional comments about the set-up-
    Example...
    Front- Stock
    Rear- Stock springs with helper springs.
    Wheels- Starions 16x7 front +14? (cant remember), 16x8 -11? rear
    Tires- 225 60 16 front, 245 50 16 rear
    Additional comments about the set-up- I don't like the set-up. it will not look this way much longer.
    Supra likes this.
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    A-arm work - 7.jpg Front- CanDo arms w/Slam RE-6 bags,custom shock mounts w/Doetch shocks
    Rearsetup.JPG Rear- Forward Tri-4 Linked w/ Firestone 9000 sleeve bags forward of the axle, custom shock mounts w/ Doetch shocks
    Wheels- Diamo 10 Karat 18-7.5
    Tires - Sumitomo 225/40 ZR18's
    Ride,handling & performance are very good,have been running this for 6 years now ,drive to all shows & weekly!:cool:
  3. Minitoy
    Minitoy Enthusiast
    So cal
    89 xcab
    We should put pics of the rides as it sits
  4. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    I agree Minitoy, pics of the whole truck too. If you have bags, then show it at full up and down so we can see the clearance you have at both times.
    Thanks TRUCK ACTION for the detailed pics. I never really thought of posting close ups.
  5. smartmonkey
    smartmonkey Veteran
    Australia
    v320, 620, 720KC, RN46, LN46, YN65 & B2200
    No suspension sitting on the trans crossmember.
    Mockup:
    255 on the front and 235 on the rear on 17's
    5 inches of tuck under the rear
  6. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Front-Cando arms with slam re-6
    Rear- tri 4link with slam re-7 on bar- soon will be ls400 irs
    Lays trans xmember an exhaust
    Wheels are 18 niche spit fires with some big ass toyo tires
  7. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    1.jpg All up ( first paint job 2007)
    2.jpg All down ( new paint 2011)
  8. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Thts all you get up front? Those are 18s correct? You shud get more lift up front unless ur limited by the shocks. Here's mine up could go a little more up front back isn't near up all the way
  9. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Only need enough lift to remove tires, & yes to 18's & shocks!:cool:
  10. smartmonkey
    smartmonkey Veteran
    Australia
    Mind if I quote this^ in my sig?
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    You got it!:cool:
  12. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    more set-ups guys. who's running the lowest static drop? i wanna know how low i can go on a ball joint flip, cranked torsions, and 4 inch blocks/ loosing leafs in the rear.
  13. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    3/4 static spindles a bit of torsion / load leaf removed 3 inch blocks not to low but lowered
  14. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    your truck looks great to me. which one is the load leaf?
  15. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Airlift all 4 corners
    Customized stock upper and lowers in front no shocks in front for maximum lift and bouncing like a cholo!!
    Bag on bar infront of axle triangulated forward 4 link
    Custom shock mounts using Ford F250 long travel shocks
    18's that I hate witha passion too wide and rub my frame, not enough room for spacers need thinner tires hahah
    Truck can be seen on my build page Ive posted enough pics to last me a few months hahah
  16. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    need pics man so others can see where it sits...
  17. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    The load leave is the one in the middle essentially the second longest leaf that is not attached to the shackles or frame mounting point . U will loose some carrying ability and will need some stiff shocks to control them floppy leafs after removal a rear sway bar def helps keep it from swaying wich helped a lot
  18. 89-ED7
    89-ED7 Member
    540 Va.
    87 2wd x-cab
    one more thing. those are 205 40 16's? what brand?
  19. scrub88
    scrub88 Toyotaholic
    tn memphis
    88 toy short bed
    Nexen extra load 205/45/16 tires chepo but surprised they don't give much fuss as my old khumo ecsta did and are less noisy
  20. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Cranked torsions pulled leafs an 3" block
