Pinion angle
Discussion in 'Suspension/Chassis' started by Lotoy, Aug 13, 2013.
  1. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Setting up my 4 link! It's been awhile what is a good pinion angle positive 2 degree? At ride height of corse
  2. Litneon
    Cocoa, FL
    94 xtra cab
    With a leaf spring setup, you'd go 1 degree or so negative (to parallel with the drive shaft). With a solid mounted setup, such as a three, four, or five link, you'll want to set it exactly parallel to either the forward half of a two piece, or the output shaft of a single piece drive shaft. And that is at ride height, of course.
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Greatly worded professor :D
    Do what he said ^ lol
  4. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    Mine, with 1" dropped motor mounts, Z'd frame and CanDo x-member ended up being up 3 degrees.
  5. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    4link
    Thanks again I've got it all tacked into place! At drive height it's 2degrees and layed out it stays about the same very little movement thru travel!
  6. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    Pics
    Pics
  7. Lotoy
    Lotoy Enthusiast
    knoxville tn
    92 std cab
    4 link
    Pics
  8. Xs5875
    Xs5875 Addict
    Greenville, Ga
    You can attribute that to those long bars! Where are you putting the bags?
