Pinion angle 3" drop
Discussion in 'Engine/Drivetrain' started by MTB68TOY, Apr 5, 2010.
  1. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    I am in the middle of swapping in a new rear axle and need to know what the pinion angle is on our trucks?
    Should I change it since I am running 3" drop leafs?:shrug:
    Here are the two 8.8 rears I picked up in Philly for $300
    the second rear was basically for the short side axle, once my long side is cut to fit the extra short axle I can have the spring perches mounted and I have a posi 3:73 disc brake 31 spline axle rear, 56.5 inches wide... 1/2 less than a stock rear axle!:waytogo:
    Axle tags L73 = 3:73 gears with posi:clapping:[​IMG]
    the real reason ford built the exploder! cheap donor axles!!:headbang:
    The taco got a little squished!:eek: heavy axles!!:evil:
    Now to find a V8!!!:love:
  2. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    Come on guys nobody knows the pinion angle??!!
  3. jetas
    u dnt have and angle finder??
  4. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    Drive down to GA and i'll hook you up with a cheap 5.0
  5. MTB68TOY
    MTB68TOY Addict
    Jackson NJ
    not too likely to ford the motor... probably go 5.3 gen4 gm
    but Ill keep it in mind since i have considered the 5.0 or 5.4 since the distributor is up front and I kinda want to do a carb motor but chevys have that darn distrib in the back and it hits the toyota firewall ( and I am not spending $$$500 on a front belt drive distributor for a chevy)
    No actually I don't have an angle finder, and even if I did or go buy one the truck has no suspension in it right now so I can't get the pinion angle of the old rear laying in the back yard now can I?
    What are my chances of anyone actually knowing this answer??!!:verdict_in:
  6. jetas
    No need to get all menstrual. It was just a question. Hmmm.......... im assuming youve searched and found nothing. Id go out to mine but i dnt have an angle finder either. haha.
    let me see if i can find anything
    edit: Ok so maybe just set it to 0?
