pic request: 89-94 yotas drop 2/3 & 3/4...
Discussion in 'Suspension/Chassis' started by moneyhungry, May 18, 2008.
  1. moneyhungry
    moneyhungry Enthusiast
    North Little Rock, Ar
    93 Yoda.
    just like the topic says. im trying to get some pics of extended cabs dropped. preferably with wheels size and tire size. tryin to figure out what i need and what its going to look like.
  2. Litneon
    Cocoa, FL
    94 xtra cab
    This one has a 2/3 drop. Spindles up front, lowering springs in the rear without blocks. The frame has been notched for the addition of bags, and I'm running the 4wd front end. Shaved antenna and third brake light. The wheels are Axis Reverbs, 18"x7.5" fronts (-42mm offset with a 1" spacer) with 225/40-18 tires, and 18"x9.5" rears (I can't remember for sure, but I think the offset is -20mm) with 265/35-18 tires. If you want to know for sure, ask and I'll pull a wheel and check.
  3. moneyhungry
    93 Yoda.
    thanks man. you have any problems with that wide of a wheel in the rear? i like the look. im running 15x8 with 4.25" rear spacing. im also running a
    225/60/15 tire. looking at my set up i think that im going to rub if i drop it. i know for sure that i will have to get the 4runner fenders and bumper for the front to even get close to clearing. i will takes pics later and show you. this is what i have now...
  4. Litneon
    Cocoa, FL
    94 xtra cab
    It doesn't look like it will rub, but we'll see when the time comes. I know for sure that if it clears, I will have to be very careful that I don't lay it out with the wheels turned even just a little bit.
  5. StupidSheet
    StupidSheet Addict
    Canada
    Here's a pic of mine. It has a 2" drop in front and I'm not sure what the drop is in the back. I just bought the truck and it's my first lowered vehicle. I do know it's a "flip converison" (I think that's what you call it) in the back.
      File size:
      94.4 KB
      213
      File size:
      74.9 KB
      217
  6. Litneon
    Cocoa, FL
    94 xtra cab
    Well, the 2wd's came with the springs mounted on the underside of the axle, so chances are it's not a flip. However, the methods of lowering a spring-under axle are (in order of my favorite to least) lowering springs, blocks, and the infamous "remove leaves from the pack until its as low as you want it".
  7. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
  8. will
    will Newbie
    not extra cab but it was a 3/3, 225/45/17fronts, 255/40/17 rear
