I dont know what the thing holding the springs is called but i think its to big for it? Also what are the bump stops for the rubber piece that is over the axle? Then my other question was what are the drop shackles suppose to do if anyone can help i appreciate it thanx
The things holding the springs are called u-bolts and with any universal drop block kit they aren't gonna fit perfect. The rubber bump stops are so the axle doesn't bottom out on the frame causing axle hop when yuu hit bumps.
Ok thanx man but i kno da u bolts cuz i put da drop block in i meant da two things in da front were the leaf spring connects to da chassis and da other on that is also on the leaf spring?
