Parting out 1977 2wd long bed 5 speed
Discussion in 'Parts and Accessories' started by ibified, Apr 15, 2011.
  1. ibified
    ibified Member
    Since I cant seem to sell this truck, I'm parting it out. Its a 1977 2wd long bed, red in color.
    The motor has been completely reworked, with new head gasket, oil pan seal, timing set, front timing cover gasket, valve cover gasket, oil pump gasket, new water pump, front and rear crank seals, etc. Engine block has been painted red, with cast iron painted intake manifold, black exhaust manifold (egr and air pump systems both deleted), black wrinkle painted valve cover, new weber carb, new starter...
    Transmission has also been gone through, it's a 5 speed. replaced front and rear trans seals and inspected gears for any problems. New clutch master and slave cylinders, and clutch and flywheel are both in good shape and are relatively new.
    bed is in excellent shape, has almost NO rust on it, and inside of bed is clean.
    Interior is in decent shape. a couple minor rips in the seat, but could be easily fixed. it has a steering wheel from a 2nd gen celica in it.
    if there's anything at all that you need, let me know. if i have it, I'll make you a great deal on it.
    email me at [email protected]
  2. Seventy6Celica
    Seventy6Celica Member
    San Gabriel Valley
    75 Hilux
    Are the coil springs uncut? If so, how much?
  3. ibified
    ibified Member
    truck has been scrapped.
  4. 81SR5Al
    81SR5Al Addict
    Vancouver Wa
    1980 SR5
    Never mind, found one locally.....
