Parking/dome light not working.
Discussion in 'Interior/Electronics' started by yota89, May 21, 2013.
  1. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Need help again my parking and dome lights don't work all
    lights work such as head light brake light signal light but
    don't have dome and parking light has anyone ever have this issue
    Lmk thanks
  2. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    Did they both work previously?
    Did they both stop working simultaneously?
    Did you do (or have done) any work on the truck recently?
    First thing I'd check is fuses.
  3. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Just finish overhauling my motor checked all fuses kick panel and
    Fender wall all fuse are good
  4. yota89
    yota89 Enthusiast
    guam
    89 single cab
    Anyone
  5. raylcc
    raylcc Addict
    Denver, CO
    Is there a chance a wire got crushed or pulled during the install? Also, double check all your grounds and make sure all of them are on properly and that the terminals aren't loose. Same for + connections as well.
  6. geonbugman
    geonbugman Member
    Columbus
    93 Pick-up
    Did the same thing on mine. fried the fuse under the hood, fixed the wire going up the a post and replaced the fuse.
  7. riceratyota
    riceratyota Veteran
    backwoods oklahoma
    which one 77/78/79/81[r.i.p]82 sbrc driftbox, and a CeliLux/current daily= 79 sbrc [lil' blue]
    side marker light Inner housing crumbled and let the wires short against the fenders so I just unplugged them until I get a chance to build new inner lenses I build them out of pop cans cut and bent with a orielys bulb socket just had mine do the same thing a few days ago so I flush mounted the lenses with nothing behind them and ground some of the plastic off to make the plastic flush with the metal
